abf cambelt.....
Discussion in '16-valve' started by RIP-MK3, May 18, 2009.
  1. RIP-MK3 Forum Addict
    sunbury on thames
    tried to do the cambelt today, have a genuine belt + tensioner.
    I just could not get the bottom pulley off to release the bottom part of the cover?? I undid the four allen key bolts probably not needed, and was trying to undo the nut in the middle?
    trouble is the box is off, and I can't figure out a way to stop it spinning?
  2. DGT
    DGT Forum Member
    The Highlands
    do you mean the bottom crank pulley ? once the allen bolts are off it should just knock off IIRC.. the big bolt doesnt hold the pulley on
  3. tshirt2k
    tshirt2k Forum Junkie
    Herts
    I had this problem too. The nut don'tt need to come off. After the allen bolts are off, try tapping the pulley off. Mine was tight on too. I removed the nut and separated the two. If i'd have known id have try to separate it without removing the bolt.
  4. LregG
    LregG Paid Member Paid Member
    undo the 4 allen bolts and 'walk' the pulleys off with two screwdrivers
  5. 1982.rpd Forum Member
    Dont undo the nut in the middle!
  6. DGT
    DGT Forum Member
    The Highlands
    you can hold it with a 19mm socket to put the allen screws back on
  7. Sukh
    Sukh Membership Team Admin
    the driveway
    As mentioned above no need to remove the crank bolt in the middle, remove the allen bolts and take a soft hammer to it.
  8. RIP-MK3 Forum Addict
    sunbury on thames
    sweet, i did try but you don't hit with full conviction unless you know it is right :)
    In terms of timing, there are the obvious marks on the top pulley, do the others have marks or do I have to make them myself?
  9. tshirt2k
    Herts
    flywheel and bottom pulley has marks too. Bottom pulley lines up with mark on timing belt cover. May be hidden under grease though.
  10. Matt82
    Matt82 Forum Addict
    GTI Scene
    bottom pulley can be sketchy as the cover can be moved about.
    if your flywheel has marks still, that makes it a doddle, worst case you put a 3/8 drive extension down spark plug 1 and do it from there
    mark, you doing the water flanges whilst its in bits?
  11. rubjonny
    bottom pulley has a hole on that lines up with a dimple on the crank sprocket, that'll get it roughty correct, as it has a little play when bolting up and as said the bottom cover can move. always use the flywheel mark when timing it, much more accurate.
  12. beetie
    beetie Forum Member
    leicester
    as matt said just use something down spark plug hole no.1 to make sure it's at TDC. i use the dipstick as it's always to hand and plenty long enough.
  13. gillm
    gillm ***** User
    yeovil somerset
  14. Matt82
    Matt82 Forum Addict
    GTI Scene
    id love one of those. i could have done with one in december as mine didnt have marks on its lightened flywheel
  15. gillm
    gillm ***** User
    yeovil somerset
    a lightened flywheel should have marks on it .
  16. RIP-MK3 Forum Addict
    sunbury on thames
    right, I was under the impression that I can just mark each pulley's position and put new belt back on without moving anything? guesse not then.
    is there any guide to getting the timing right? im scared!!! :lol:
  17. Matt82
    Matt82 Forum Addict
    GTI Scene
  18. Matt82
    Matt82 Forum Addict
    GTI Scene
    line up this
    and this
    and then the flywheel/stick down cyl 1.
    then get the belt on starting from the crank, go back anti clock round to the cam pulley.
    put the tensioner on and line it up like this
    turn the crank over by ratchet clockwise a couple times (spark plugs out)
    the timing marks have to line up after, including the tensioner mark. if the tensioner doesnt, adjust the tensioner
    after that put the new water pump on that your mate broke whilst trying to loosen of the pas pump for you and torque it all up properly, otherwise you get this
    change some flanges just to make your life a bit harder, but you may as well do it
    take the engine from something messy to something working in a few hours.
    take back the water pump to vw as your shake down run, have a shower and then immediately head off 200 miles to cheshire
  19. RIP-MK3 Forum Addict
    sunbury on thames
    sweet thanks pal. not as daunting as first thought then. Is it a good idea to count the teeth on the cambelt from say the crank pulley to the cam pulley and make sure new belt is the same?
  20. Matt82
    Matt82 Forum Addict
    GTI Scene
    not really tbh. because of the teeth its pretty easy to work out when its right. one tooth off is quite far off
