and the vw stuff is pretty fast, and free. However without serous mods, there is no point in remapping it for small capacity a turbo will give the most bhp/
Right, it really does depends if you're going to run it naturally aspirated, or forced induction to what ECU you choose. As for having a base map on emerald as benificial, not a hope in hell im afraid, you'll be able to start the car and thats pretty much it, it won't idle, rev freely or anything. Emerald is an perfectly acceptable choice IF you're going naturally aspirated, and dave walker will map the whole car for 240. I garentee his rollers are miles better than jabbasports, TSR's, stealths etc etc. They 1600's have the potential to be a cracking revvy monster of and engine due to the short stroke of em.
ive seen his car, totally stripped the roof lining and carpet, all out just a cage and buckets and the dash (airbags also out) i know he will have money to do what he wants just not what other people want
What I don't understand is what benefit you are looking to get from running a programmable ECU when no work has been done on the engine. Surely it makes more sense to do whatever work you want to do on the engine first then get the ECU mapped afterwards, or have I just completely mis-understood?
You're half right edc, electronic mappable ignition on a car that uses bob weights to advance the ignition will always give better power in general. for modern ignition/forul systems, you're right.
correct TT, P.S. hows your project getting on? ok, i wasnt going to go into this, but it seems i need to the spec i was going for was: AFH 16v head,worked on 256 or higher cams 45mm TBs , 120mm trumpets rebore/restroke to 1800cc lightend balenced bottom end 6spd lupo box with different final drive now as i said, this was just to put me on for a while as i also said, 75bhp from a 1.6 8v is a bit down so is the general idea that i wont gain much....? idea has now changed for the head, but im keeping that under wraps.....as my mind is always changing and im not sure if it will work... comments are helpfull, cheers
this was just a question as to whether i should go on a base map for a while untill i build my small block, i have my plans and im sticking to them
should run on a generic map if all the sensors types are configured properly well enough to limp it to a RR
so thats a resounding no to gaining owt on a base map over my OE ECU and its map, ok, thanks to everyone that replied.
... well I would say 100bhp from a VW 1.6 8v engine ain't bad considering the 1.8 gives 90bhp and the 2.0GTI gives 115bhp
Sorgs 1,6L 8v with ported head, throttle bodies, Weber throttle bodies and Weber Alpha ECU puts out 136 bhp
thats my point polo classic you have to spend out serious to get 136bhp from a 1.6 when you could use a 1.8 16v costing 200 or a 2L 8v with a flowed head and cam for under a grand. I didnt do A level economics for nuttin lol
thats what i thought, but my friends in the 20XE world assured me 45s would be better then 40s on a 1.8 16v..... confusion is there no maths for what dia. for what cc, etc?
