Pick up my gearbox on monday all to be fitted next weekend a few boost pipes to change as ive bought one of these its even bigger than my coffee mug
@toyotec going by the list you posted does that mean the AGU style injectors will not work the with me7(aum)? Or is it literaly a case of changing injector loom?
From what iv tried to gather me7(aum) run ev6 injectors at 12 ohm and the original agu injectors are ev1 and are 14 ohm so appently wont work with me7?? Is this correct? So i should source some aum/auq injectors ?
Just adding a link as it covers more issues I have come across http://www.clubgti.com/showthread.php?277017-Help-needed-to-identify-these-plugs-on-a-1-8t-conversion&p=2384184#post2384184
Yes they will work with the ME7 injector driver. Less current draw. However AUM EV6 injectors are 315cc/min and the AGU EV1 286cc/min.
ah ok id already bought some ev1 c20let yellow injectors that are 306cc i believe (then was told they wont work) so these should work fine on me7 then? Thanks
