What selector is the best option to use in golf mk2 running cable change 02A. I have a corrado one at the moment and I find the actual lever too short. Other than extending the current on what is the recommended ideal gear selector to use please. Cheers
Cheers But then I need a mk4 shift tower also..... If anyone has both for sale then great otherwise which one best fits the std tower. Has anyone got one
Pretty sure all 02a are the same, and notoriously sh*t so I would get a MK4 shift setup when one comes up for sale. That's what i'm doing as its the most cost effective upgrade.
Is it a straight fit? I dont want to do this if it involves any major mods (cutting bits of bodywork etc). I always understood that the cables are not long enough?
theres a how to online somewhere, dont think its any worse than using the standard cable jobbie i dont have it on mine so cant comment advise anymore ..i will be looking at one when the funds allow
It is a bit confusing as you need to get matching shifter and shift tower if possible, as there are early and late types of cable fittings at the gearbox end. What engine are you running? http://clubgti.co.uk/forum/showthread.php?t=193257 This should help you out as it details how to do it without modding the tunnel.
Looks like I dont have the time to go Mk4 right now. what is the best alternative: Passat, Mk3 etc. which shifter matches the 02a box to get a longer lever then the corrado one? Any particular model I should be looking for?
Mk3 will match the box, and is pretty straight forward to fit without modifying the tunnel (small modding of the shifter box needed. Mk4 is better, as said, but needs the tower for the box (as you know), which is easily done, and the tunnel modded to fit. Willber`s link above shows the best solution; Polo shift box (straight fit to tunnel) with Mk4 shift mechanism retro-fitted into it. Still need the shift tower obviously...
Im my mk1 i'v used mk4 shifter and mk4 cables with standard 02a tower gearbox end I just modified cable ends to fit, was a very good shift Other way of doing it is relocating your shifter inside the car, that will raise it 3 inches!
Cheers all, I am going to do quick fix and extend the lever on my rado shifter for a temp solution whilst I source the Polo/Mk4 parts like the link above
Is this all I need from the MK4 setup? How do I know what fits with the 02A? This one's an early one, will the cables be long enough?
The cables will be plenty long enough, but you will need the tower from an 02J Mk4 `box, since the cables ends won`t fit the 02A tower. Or ask Sambo how he modified the cables ends to fit.
Still don't understand what a shift tower is, your previous picture didn't work. Does it go on the gearbox end? Is it this?
