cheap as chips rust remover
Discussion in 'Tools, Equipment & Fasteners' started by altern8, Feb 3, 2009.
  1. neil kaye Forum Junkie
    england
    who me ??:lol: yea they look great now are you going to paint them
  2. Admin Guest
    get all the rust off them before you do paint them, it comes back with vengence if you don't
  3. mk216valver Forum Member
    yeah, gotta get the really stubborn rust off and then paint them, or maybe powdercoat along with some other stuff, need to find someone that does it locally and get some prices.
    anyone recommend any brand of paint for doing them?
    Cheers,
    Jon
  4. neil kaye Forum Junkie
    england
    when i get round to doing mine i was thinking of just using caliper paint
  5. tinydubs
    tinydubs Forum Member
    try and get your mitts on polyurethane paint, its the next best thing to powdercoat and is chemical resistant.its used to paint trucks, brake dust won`t touch it. it should be available from motor body specialists, as a two part mix
    if you have asthma though i recommend you get someone else to do it, [xx(]
    and wear a mask!!!
  6. mk216valver Forum Member
    ok, cheers for that m8 i'll keep an eye out for that
    thanks again
  7. richard s Forum Member
    im currently doing some brake calipers that were severly rusted but as said with the vinegar and a wire brush in a drill they are looking unbelievably like new and plan on etch priming then using some hammerite aerosols
  8. Steve B Forum Junkie
    Manchester
    Im just wondering if i can use this method to remove rust on some BBS RM bolts I have, If i were to put all the bolts on a metal base, makeing sure they were all making good contact, or screw them into something metal, in theory this could clean them up? can anyone see an issue with this?
  9. Steve B Forum Junkie
    Manchester
    or would they all go black? how easily would they polish up afterwards? does anyone knwo the type of metal the original bolts are made of? is it steel?
