cracked flywheels, ideas!!
Discussion in 'Transmission' started by coupechamp, Apr 2, 2010.
  1. danster Forum Addict
    Chris and Dave, you need to troll back through the previous incarnation of events. Stop hanging out in the general chat section.:lol:
    This is a "cracking" thread by the way.;)
    I'm off to talk about the Focus "RS500" in the technical sections - seeya!
  3. Dave
    Sligo, Eire
    IIRC, vibration dampers are designed so that the crank thinks there is a weight stuck out in front of the crank. At first thought, I assumed it would only effect vibrations at 90 deg to the axis of the crank. Now I think it will also work axially as well, cos, it is free to moved in both planes!
  4. Dave
    Sligo, Eire
    I'm going to watch "Ashes to Ashes"!
    Bit of a read, but this thread is full of stuff about harmonics.
  6. alexisblades99 Forum Member
    sunny helsinki
    i'm starting to get worried reading this, tsr sold me a eurospec flywheel last year and the engine's been vibrating a bit lately.
    i'm guessing some quite bad things would happen if the fly let go under full power? are we talking stitches crutches or wooden boxes here?
  7. A.N. Other Banned after significant club disruption Dec 5th 2
    Bent crank & cracked blocks at high revs. Terminal stuff due to the inertia drop.
  8. MUSHY 16V
    aberdeen
  9. A.N. Other Banned after significant club disruption Dec 5th 2
    Wow. Throw the guys a link tbh.
    If I were running a Eurospec flywheel, I get it straight off the car asap. When I say above 'bent crank & rods', I've seen two, first hand. Has the potential to cause the huge damage you see, but the inertia drop will write off the bottom end regardless.
    If you've got money in your engine, it'll absolutely destroy your investment. Don't risk it.
  10. MUSHY 16V
    aberdeen
    also they look cast i would want a billet steel one if it was me
  11. danster Forum Addict
    I am fairly sure Eurospec will be aware of these failures now with the various correspondence they will have had from certain parties.
    Does not look like the bolts were slack on the vortex pics though but it has bust in the same place.
    Are people putting in mega strong clutches to cope with the power, and thus needing large loads to release the clutch?
    They appear to be cast rather than billet steel to my old eyes, so sourcing a billet one may be the best way forward for anyone looking to buy in the future.
    Edit. x2 mushy
  12. alexisblades99 Forum Member
    sunny helsinki
    cosmic. just cosmic.
    do they not design these things properly or what?
    iirc they are cast yes, with the starter ring being steel. i vaguely remember the bloke at tsr saying something about how they changed the design from two-piece to one-piece at some point? not sure it was a while ago.
    Eurospec do make a lot of stuff: cranks & 8-valve heads notably (in my recollection).
    Something appears to be up with the quality of those flywheel castings.
  14. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    seems amazing, that many failures all from the same brand of uprated item.
    whats the 'benifit' of these? a lightened unit pre built ready to use?
    Billet item for the shopping list?
    Yep, these are just an off-shelf version of what can be machined down from OEM, evidently using some ropey casting design (not thick enough?) or shoddy metal.
    OEM ones can be down to 6.5kgs, and they work fine.
  16. danster Forum Addict
    Is the market for them there as folk do not use the dual mass ones and the supply of ABF style is limited?
  17. MUSHY 16V
    aberdeen
    yes that's pretty much it
    lots of people are looking to get shot of the dual mass setup
  18. A.N. Other Banned after significant club disruption Dec 5th 2
    No old cable change single mass flywheels available in the USA?
    Corrado, Passat, Mk3?
  19. MUSHY 16V
    aberdeen
  20. MUSHY 16V
    aberdeen
    and looks like they use the same flywheel for all the kits
