Hi, Just wondering what opitions are out there for a 20vt mark 1 running on megasquirt in reguards to EBCs? What has been tried and tested? What are you using? Whats good value for money? I'd want switchable maps idealy. Any recomendations? Links to cheapest place's to buy certain EBCs would be great as well Cheers and thanks for your time! Leon
we use a lot of greddy profec b spec 2 controllers at work, very easy to install with the only wiring being a live and an earth. they do a high and low boost setting at the touch of a button and can also be turned off for an lower setting. hope this helps
Shop around in Egay and they sell for 220 to 300 quid. Good lil controller that. Had a profec B before updating to the spec 2. Even better with the wireless transponder. Also look at HKS EVC * units, Apex-i, Blitz and Gizzmo units. All will work and not hard to install.
I was thinking of using an Apexi unit. My friend has one on his Skyline (an AXVR) and it seems to do the job well but I dont recall it being a cheap bit of kit.
That would be an AVC-R. This has programmable gear detection (needs electronic speedo input and engine speed), allow you to control solenoid duty per gear. Expensive but pretty effective.
My 'squirted mk2 has an apexi fitted - linky. I don't use all of the functions, but do have high and low boost settings enabled (low gets used all the time mr. insurance man...)
Fantastic news is I've just had my turbo off and its not f00ked like I thought. Just needs new gasket to manifold and studs re-tightening. I now have some cash freed up... me thinks boost controller is on the cards...
Thanks for all the replys, have had a look on Ebay for most of the controllers mentioned, only problem is all the auctions seem to be "from Japan" which seems abit dodgy,lol
yeah im looking at getting a gizzmo one as toyotec reckens with a k03s and a ebc ill be able to get a bit more bhp and torque once hes mapped it (if he doesnt break the cv joints like last lol)
Any chance of a direct link to said Gizzmo EBC by any chance tshirt/ben? Seems to be loads on ebay for all different cars and from different places
Ebay's the best place or direct from here. They're not specific to any car. Thats how the advertise them.
Built one ECU and got boost control to work. Only downside you got to bring the laptop out to change thresholds.
are you guys after ebc because you want it in car adjustable? forge mbc works a treat and is simple to setup..
