Electrolysis Everyone should try this. DIY.
Discussion in 'Tools, Equipment & Fasteners' started by Admin, Jun 3, 2007.
  1. notenoughtime
    Essex
    quality i will be doing this myself for the smaller items
  2. Jon Olds Forum Junkie
    good thread!
    Jon
  3. beetie
    beetie Forum Member
    leicester
    Read a thread on retro rides and a guy on there used carbon rods as the anode instead of the lump of iron.
    It would be a slightly more expensive set up as we would have a brake disc lying around, but no carbon rods.
    Looking at it the derusted parts come out cleaner needing just a quick scrub.[emoji106]
    Found a good link for it. All be it a ford one(sorry)
    http://www.fordgarage.com/pages/electrolyticderusting.htm
    Nige, Sirguydo and EZ_Pete like this.
  4. aminder
    aminder CGTI Committee - Webmaster Staff Member Admin
    Leicester
    Great for nice clean car bits.
  5. neil kaye Forum Junkie
    england
    copper piping works well too
  6. beetie
    beetie Forum Member
    leicester
    I think I remember reading that copper causes toxic fumes
  7. DeanH New Member
    Do you reckon this would work in something like an inflatable paddling pool?
    I'm thinking of dropping my whole rear beam in and can't really think of anything else big enough to do it all at once.
  8. Sirguydo
    Bolton
    You don't have to do it all at once can do half at a time with no lines as only dissolves the oxidised metal :thumbup:
  9. Finite
    Northamptonshire
    Another option would be draping thick polythene over 'things' laying the beam squashed milk cartons or similar to stop it poking through. This way you can get tighter to the shape of the beam and keep the volume of fluid down. Personally I probably go for Deox C now it cleans microscopically better and there's a lot less to do afterwards. If you don't have much knocking about CLS timber is cheap and radiused ideal to form the top edge.
  10. Sirguydo
    Bolton
    Just read the carbon rod link that is awesome lol
    The carbon rod seems to cure any difficult cleaning afterward parts look brilliant after a wash with water :thumbup:
  11. Finite
    Northamptonshire
    I'll have to see if I can find a carbon rod to try it on small scale, but it seems to still come out jet black. Those stub axles I did look shiny yet there was always endless black in the tiny pores that could be drawn out with further brushing and wiping with white spirits.
  12. Sirguydo
    Bolton
    Not done this yet so you're more of an expert them me lol
    Guy in ford thread says just washes off with warm water you can always go to the next step on any thing you do in life it's just wether you can be bothered or not and how far you want to go ;)
  13. DeanH New Member
    If it converts it back to iron, is there any point in coating it in rust killer after electrolysis?
    Can I get away with zapping it then going straight in with some primer and paint?
  14. nut 20v
    nut 20v CGTI Regional Host - Birmingham & Midlands
    Overtaking you
    The oxidized metal flakes off leaving good metal underneath, the oxidized metal turns black and is flaky and breaks up easily and falls away from the good metal,it may need a little scrape or wire brushing to remove but the process does not convert the rust into good metal.
  15. Boksic Paid Member Paid Member
    Cushendun
    I remember reading this a few years ago, and now I have some rusty MK2 bits to try it on. Class.
    Has anyone that's used this process changed anything or found any good tweaks to solutions or anything?
    This thread probably deserves the bump for us newbies anyway!
  16. AndyBa Paid Member Paid Member
    Sheffield
    Not read through this whole thread, but for a lazy alternative use molasses diluted in hot water. Look at the vids on YouTube.
    You can buy molasses already diluted from cattle feed suppliers or just get granuals from the supermarket and dilute with hot water. Fill a bucket/bowl drop the rusty part in and place it in the garage for a week or two.
    Wind forward 2 weeks and scoup out the part. It will be covered in slime. Use a wire brush and rinse with fresh water. Be amazed at the results of your hard work!
    I've only used it on steel parts.
    Boksic likes this.
