help please !
Discussion in '8-valve' started by Razzer, Aug 4, 2010.
    Thanks Ray. 82.25 seems to be F3 spec.
    With a 94 crank.
    What's in yours, any idea?
  2. Razzer Forum Member
    No Idea ! Haven't touched the bottom end apart from removing the sump, is there any way of identifying or measuring without stripping
  3. drunkenalan Paid Member Paid Member
    Leicester
    i was looking at buy some pistons from omega a while back.. they asked if a set of F3 83.25mm would be any use as they had made a batch recently... maybe they were over sized versions..
  4. danster Forum Addict
    Put the piston as far up the bore as it will go. ie TDC It may be proud of the block by a mm or so.
    Then put the piston to the bottom of it's stroke. ie BDC, and measure how far down it has gone. This will give the stroke of the engine, which is double the crank's throw. :thumbup:
  5. Razzer Forum Member
    Her in doors says '' you lot have got too much time on your hands have you tried decorating'' !!
    Sign 'Her' up to the forum - she'll love it!
  7. danster Forum Addict
    I spend so much time on here, that I have not got time to build the house, so do not need to decorate it!! [:D]
    This thread is called "help please", maybe I should get some professional help myself. :lol:
  8. Razzer Forum Member
    Hi All...........92.5mm ?
  9. A.N. Other Banned after significant club disruption Dec 5th 2
    92.8mm surely?
    It does look OEM to be fair
  10. danster Forum Addict
    Sounds close enough to the oem 92.8mm std 2.0 engine stroke.
    Your new 2E block will have the same. :thumbup:
    Tell your Missus I am managing to reply to your thread and cook haggis, tatties, broccoli, carrots, peas, and make a gravy without lumps at the same time. ;)
  11. Razzer Forum Member
    Could be, only using a steel tape from B@Q not the best, must get a new vernier gauge
  12. Razzer Forum Member
    danster,
    she says, she's on her way, GOOD LUCK !!!
  13. danster Forum Addict
    I forgot to say I have been drinking a few beers too. :lol:
    Not got to the point the beer goggles are in full effect mind, hopefully I won't need them. :thumbup:
    You should tell her there are several engines in my living room, better the devil you know. ;)
  14. Razzer Forum Member
    just phoned her, she said OMG your all the same !! ,shes on her way back, Thanks [:^(]
  15. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    If the price is right Alan then yeah.
    82.25 is the common F3 size, but they could have used anything and had cranks and rods made to suit... we're talking not very limited budgets here remember.
    Omega are probably doing a batch for classic F3... still big business.
    They may have odd pin sizes to suit custom rods tho, so would need to watch that.
  16. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Prob just under 82.5 Ray to suit the common bore, the piston will be a touch smaller than the bore... sorry, teachin granny...:lol:
  17. drunkenalan Paid Member Paid Member
    Leicester
    My concern was about the F3 engine ran V High CR as they were running air restrictors.... I guess by now tho most are running without restrictors and have lowered the CR apprpriately.
  18. Brian.G
    Brian.G Forum Member
    West of Ireland
    Forged crank too:thumbup: They came in 6As at the time. Im sure of that, mine had one:thumbup: Not saying this is a 6A engine of course, more-so that its prob a 6A crank. My 2e of the same era has a cast crank.
    <Rant>
    BG
  19. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Depends on the piston spec Alan... are they flat top or dished? If flat topped, are they designed for long rods with a thin-ish crown or std rods with thick crowns to allow a bowl. If used with a chambered head a bowl of around 5-10cc will be needed, subject to spec & required c.r.
