Irwin bolt grippers
Discussion in 'Tools, Equipment & Fasteners' started by Hodder, Mar 14, 2008.
  1. Matt82
    Matt82 Forum Addict
    GTI Scene
    i used them twice yesterday. i had a "replace bolts that ive shagged in the past" afternoon. battery tray bolts were corroded to buggery and rounded down to nothing, even with a 6 side 10mm.
    the bolt grip got them out in seconds.
    i cant remember which set i got, but ive done the carrier bolts and some dead 10mm ones too
    in fact, i did one of the inlet manifold bolts too that i killed at one stage also
  2. Riley
    Riley Forum Addict
    Burnley/Lancs
    Guys, i notice on the amazon reveiws that people mention the 10mm being too small to actually use on a 10mm headed bolt?[:s]
    Anyone else had that problem?
    Edit:Are these the sizes in the 5 piece set? 3/8" 7/6" 1/2" 9/16" 5/8"
    Cheers,Neil.
  3. tallika_fan
    tallika_fan Forum Member
    Northwich
    I agree with all the above comments, where have these irwins been all my life, ahem.
    Stuck undoing carrier bolts on the ibiza we had, getting well riled and cursing, bought this set and got it off no probs. Just need to complete the set with the expansion pack.
    Even helped out removing the 3 balljoint bolts which had broken the weld/bracket. though that was a bit awkward with a bunch of extensions for the ratchet.
    :thumbup:
  4. Matt82
    Matt82 Forum Addict
    GTI Scene
    that is the set i have, that worked for the carrier bolts and the stump of a 10mm bolt i took out on sunday.
    ill try n get a pic up of the battery tray bolt i took out, nothing left of it
  5. RIP-MK3 Forum Addict
    sunbury on thames
    i have both sets now due to ordering the wrong one's, quality bits of kit
  6. Riley
    Riley Forum Addict
    Burnley/Lancs
    Cheers mate:)
    Neil.
  7. Mike_H Forum Addict
    I generally find that one of them will fit... a good smack with a hammer helps if they're a bit tight.
    Battery tray bolt is 13mm head in my cars...
  8. Brookster
    M1 J40
    Irwin grippers are excellent just seen this post :)
  9. Matt82
    Matt82 Forum Addict
    GTI Scene
    one of mine died lastnight
  10. tallika_fan
    Northwich
    Must've been a fecker of a fastener to bust one of them!
    You got any pics of it? The busted tool i mean.
  11. Matt82
    Matt82 Forum Addict
    GTI Scene
    ill get some for you
    i checked the irwin site, the tools have a lifetime garantee provided are are not altertered or misued
    mine was not misued so ill go back to machine mart
    10 bet says i cant find the receipt
  12. Jaundice
    Jaundice Forum Member
    at home
    Do these work on round headed bolts? Not rounded off I mean ones that were round to start off with?
  13. pigbladder Forum Addict
    cambridge , uk
    yes they do
  14. Jaundice
    at home
    Awesomenessticity!!!
    Thanks!!!
  15. Matt82
    Matt82 Forum Addict
    GTI Scene
    they will work with rear brake carrier "bolts"
    just remember to torque them properly when you put them back on
  16. Jaundice
    at home
    Whats the right torque mate the book of lies doesn't say so I've just copper eased them and tightened them up tight again, but I can torque them properly again when I check the bearings in about 100 miles?[:$]
  17. pigbladder Forum Addict
    cambridge , uk
    good n tight is good enough....mine never fell off
  18. Matt82
    Matt82 Forum Addict
    GTI Scene
    70nm for the rear. as for the bolt grips, get them from machine mart, you need the set that comes with the box, that one has the one that does the rear carrier
  19. mk28vICED Forum Member
    Rugby
    yeah the rears need to be as high as matt82 suggests i've had them come loose and lock one of the rear wheels!
  20. G60RCaol Forum Member
    Can anyone tell me which kit i'll need for them to grip a rounded 17mm bolt?
