It has arrived - Aldon Amethyst Mappable Ignition
Discussion in '16-valve' started by Craigcorson, Mar 17, 2015.
  1. Craigcorson
    Craigcorson Forum Member
    Inverkip
    It has finally arrived, had to wait on the TPS sensor but my mappable ignition is finally here
    All neatly packaged so it felt like Xmas all over again
    Everything appears to be here so the first thing i did was to wire up the TPS sensor, 3 wires all clearly labeled and instructions are included. I crimped, soldered and heatshrunk the wires to make triple sure. I dont think they will get pulled off much but it'll help to keep the connection good for years to come
    The only slight hiccup in my plan is the dizzie connector. Its not the ENG3 that aldon have sent me. Looks an easy mistake to make. Does anybody know where i can get a NEW one of these. My old one has more connections than the london tube system
    Ive also tried the software side of the system. All you have to do is plug the supplied stick into your laptop and open the program! So easy even i can manage it
    Brian.G, Nige, Sirguydo and 2 others like this.
    looks liek bog std vw plug right? if so its 357905327 ant 3.83+VAT. uses normal junior/power timer pins and wire seals :)
    Jon Olds and Craigcorson like this.
  3. Craigcorson
    Inverkip
    wheres the best place to get one jonny? I just went down to the car to have a decent look at it and snapped the bloody wires again! Back with the soldering iron before sunday!
  4. bootsie Paid Member Paid Member
    Brackley, Northants
    Subscribed.. :thumbup:
  5. Craigcorson
    Inverkip
    Found it on a russian website but none in the UK
  6. bootsie Paid Member Paid Member
    Brackley, Northants
  7. rubjonny
    yeah thats the VW part number and price, phone your local dealer :thumbup:
  8. Craigcorson
    Inverkip
    local dealer is getting 3 for me. Should be here saturday. woohoo!
  9. fasteddie
    fasteddie Banned
    "looks liek bog std vw plug right?" garage slang ...love it! lol
  10. rubjonny
    sometimes my Yorkshire heritage shows :p
  11. Tristan
    What's the advantages of this over say Megajolt?
  12. Craigcorson
    Inverkip
    For me personally,
    ease of set up
    no fabrication reqd (ie trigger wheel and sensor mounts etc)
    no trigger wheel to get bashed (its on a rally car)
  13. 16vlover Forum Member
    canada
    what is the cost of this set-up?
  14. Craigcorson
    Inverkip
    So far 310, but i have not fitted it yet!
    Plugs are on back order from VW, i doubt i will get them but Ive been wrong before.
  15. Jon Olds Forum Junkie
    a lot more expensive than a clockwork dizzy. watching with interest how it all works out.
    Jon
  16. rubjonny
    worst case the plugs are all over the shop, mk3 era cars still use em :)
  17. Craigcorson
    Inverkip
    Sorry about the lack of updates but work has been a bit hectic!
    I've got all the required plugs now to make a loom for this set up.
    I'm hoping i've worked out the required wiring but ive mocked it up before I install it (side by side with the original ignition)
  18. Craigcorson
    Inverkip
    for those who are subscribed to this, I'm in the process of wiring it up now and hopefully test fire next week!
    Nige and bootsie like this.
  19. Tristan
    Bated breath.
  20. Jon Olds Forum Junkie
    absolutely
    Jon
