once i've saved up the cash (in about 30 years ) i'm going to be sorting out my vr's crappy suspension... i'm probably going for koni adjustable shocks and eibach springs and i've been quoted 630 for the 2 FITTED (that's with the VAT included). is this a good choice of suspension set up and is that a good quote or a rip off? Edited by: b'locks
yeah i thought it sounded a bit steep. sorry for my ignorance as i haven't ventured into the suspension side of things before...but how do coilovers differ to shocks and springs?? Edited by: b'locks
you should be able to get the eibach/koni adjustables (rebound is adjustable) setup for around 400, but thats not fitted. cheap (relatively) coilovers are only worth it if you want to go low, as they have height and rebound adjustment. unless you spend big money and get coilovers that have both height, bump and rebound adjustment. i'm gonna go for the koni/eibach's when i can afford it...there top notch...i also wanna dd a set of eibach arb's and poly bushes into the mix.
you can get between 30 - 40mm lower i'm sure, but they are set at whatever you buy, non height adjustable only damping Edited by: Dave
im running koni top adjustables with eibach springs on my mk2 8v, cost a little over 400 if i remember correctly, fitted myself piece of take a leak to do, i replaced bump stops and top mounts all round at the same time, i personally wouldnt really bother with coilovers unless you want your ride really low, mines 25mm i think im really happy with my setup, Edited by: oakgreen88
i couldn't fit them myself, i wouldn't have a clue... so basically if i could source the gear for 400 then i'm being quoted 230 labour
koni's i have are damping adjustable, not height, coilovers are height adjustable aswell as damping, the springs that you will use on your konis will lower your car
dont pay that much for fitting it really isnt that difficult, you wouldnt even give it a try urself? im sure other places will fit it cheaper than that! but remember to get tracking & chamber setup after!
yellows adjustable for rebound on the car (most models), reds off car adjustable. You can get it fitted and fully aligned for circa 150. It normally works out cheaper to buy an SSK kit if buying yellows cos the individual dampers cost more. Edited by: edc1
150 thats sound more like it, yellows are what mine are! are the reds the new range? anyone got any experience of them?
he means they are damping adjustable, you should try and fit them your self even, with a good socket set, and a couple of hours at most, taking your time. oh and i agree that labour charge of yours is completely a rip off material! and must say oakgreen88 car looks sweet in the pic! Edited by: Dave
so basically i should just buy the shocks and springs myself from the cheapest place i can find and then should only pay about 150 to have them fitted and aligned, etc? can i just clarify then, what you're saying is that only coilovers can be adjusted once they have been set up on the car and that the koni shocks i've been quoted for can only be adjusted upon initial fitment? Edited by: b'locks
