Mk2 1.8T Engine Brackets
Discussion in '1.8 & 1.8T' started by priceygti, Jun 26, 2011.
  1. Richard Mk2
    London / Bucks
    I kept my solid 8v one on mine, as there was enough adjustment on it to make it fit :)
    My setup was -
    * Mk3 16v front bracket
    * G60 rear bracket
    * 8v solid front mount
    * Rear MK2 mount
    * Mk2 gearbox mount
    :thumbup:
  2. bbart New Member
    Hi Richard, when you used the rear Mk2 mount and the mk2 gearbox mount you were still runing the original gearbox right?
    The original mk2 brackets cannot be used on the 02a/02j gearbox is what I read, the parts look also very different in etka.
  3. StuMc
    50? 20` 47 N - 06? 57` 57 E
    The gearbox-to-mount bracket is different, yes, but you still use the Mk2 resilient rubber mount attached to the subframe.
  4. Richard Mk2
    London / Bucks
    Nope, this is with my current setup using a 02a gearbox.
    As stu said above, by mount I mean the rubber "mounts" attached to the subframe. ;)
    And yes, the original "brackets" can't be used.
  5. bbart New Member
    I am now buying corrado brackets to put on my AGU engine with 02J gearbox. This info was found in another thread overhere.
    http://www.clubgti.com/showthread.php?237857-Mk2-1-8T-Engine-Brackets
    In the Golf I allready have put G60 engine rubbers because I was building it with a tuned 16v KR engine.
    This I have sold now and bought me a nice Skoda Octavia 20vT donor vehicle.
  6. bbart New Member
    haha sleapyhead... this IS the thread.... anyway found all parts on ebay.de let's hope i'll have time soon to pull the engine out of the skoda en trial fit it in the golf.
  7. rubjonny
    the front mount you buy depends on the front engine carrier, if mk2 then you use a mk2 mount, if toldeo or corrado vr6 then you use a mk3 one. the front mounts are totally different shape cant mix n match there
  8. bbart New Member
    Ok, I have the original mk2 brackets available too. I'll be using the standard mk2 subframe, maybe upgrade the front rubber to a solid version so i don't get in trouble when i order the trackslag 3" downpipe.
  9. petrolhead90 New Member
    I have 16v kr mk2 and putting a 1.8t and o2j
    Do i just use all g60 brackets as in first post?
  10. rubjonny
    You could try it on the old 16v rear bracket as some have had success with them, but the front deffo 100% have to be 02a type from g60, rado etc and gerarbox from any 02a so all rado, mk3, seat etc with 02a box including vr6
  11. Joe16v Forum Member
    Eastleigh
    if you use a stubby master cylinder the 16v rear bracket should be fine for clearance.
  12. petrolhead90 New Member
    Ok thanks so ill just need the ones listed in first post for front and gearbox? if my original works on the back of the block
  13. rubjonny
    yes, there are a couple other numbers that work too since there were a couple revisions of the various brackets.
    but basically front needs to be golf g60 or 4 cylinder corrado and most passat b3/4. gearbox any 02a so g60, mk3, corrado, passat b3/4 or seat manual 4 or 6 cylinder. rear bracket try your old one, if it wont line up right get a 4 cylinder corrado or mk2 g60 one same as the front
  14. petrolhead90 New Member
  15. petrolhead90 New Member
    Does anyone know what mounts it is that will fowel the m/c?
    May be doing away with servo do wouldnt be an issue
  16. petrolhead90 New Member
    Only just noticed this! If i use the original rear bracket. Can i not use the original front bracket? Or im guessing not compatible with o2j?
  17. Joe16v Forum Member
    Eastleigh
    Rear engine bracket has nothing to do with the 02j box so can be used. The other two brackets bolt to the gear box so you need 02a items.
  18. rubjonny
    the rear brackets are always different for cars with cable shift gearboxes, so you my find te 020 bracket doesnt line up with the front mount. some have had problems, some have found they have enough 'wiggle room' so give it a go before you spend money basically
