Not sure of the code as can't make it out on the transmission case albeit I'm pretty sure its an O2M as its looks to be a twin output shaft box and as far as I can tell from Elsa it would be the exact same ratios as the R32 box. Is there an OEM SMF solution in either case?
I'm not aware of any OEM solution for the 240mm clutch setup used in 02M boxes sadly Otherwise I'd be using it!
Sorry, It's not VAG parts bin no, it's Mardi Gras motorsport supply them IIRC Alan, they do a kit including SMF/Clutch etc to convert 02M. http://www.helix-autosport.com/home-page/ No prices as far as I can see.
Sachs do one for 02M (4 cyl & TDI listed here) http://www.darksidedevelopments.co....ywheel-smf-clutch-kit-for-vw-02m-6-speed.html
Helix set up is around 900, i know as i used to run it prior to Spec stage 3+ i am on now Helix is a very good set up but is chattery
