My Mk2 Golf 20VT Berg Cup Project
Discussion in 'Members Gallery' started by mk2sp, May 26, 2009.
  1. mk2sp Forum Member
    GREECE
    Had my ATS DTC wheels arrived yesterday.
    Appropriate Dunlop slick tires were put on the wheels and the car was ready for some testing.
    Testing showed really nice dynamic behaviour, with great traction and front-rear balance. Needs some more power though...
    Next step...Roll cage & stripping interior out
  2. jettadan Forum Member
    Lancaster
    :thumbup:
    Looks like fun!
  3. ^panos^ New Member
    Greece
    Nice work :thumbup: , it's very rare to see this kind of project in Greece...
  4. mk2sp Forum Member
    GREECE
    After an engine failure a rebuild was necessary
    Honing finished
    Same AEB/AGU piston and rods (were in good condition) but new piston rings and rod bearings
    Rebuild cylinder head with new Supertech valves, new guides and sealings, 20V N/A inlet camshaft, K04-023 turbo and ex.manifold (shown) all assemplied
    New downpipe was manufactured (to fit K04-023 turbo)
    Next, it was time for a better-bigger intercooler (7.7lt capacity)
    Trying best place to fit
    An extra bar was welded for stronger support
  5. mk2sp Forum Member
    GREECE
    New oil catch tank and new intercooler pipes
    New Passat 1983 1.6D A/C radiator was also installed (a little bigger than VR6 Corrado, Thermostat: 83 C , Fan switch: 88 C)
    Finally, new side free flow exhaust
  6. 16valver Forum Member
    Looks awesome.
    Where did you get the DTC's?
  7. mk2sp Forum Member
    GREECE
    Got them straight from ATS Germany, for about 1000euros including shipping to Greece.
  8. JamesL Forum Member
    At Work
    Looks very nice, did it come with the digifiz?
    maybe a rallye front end would suit it better if it fits with the intercooler?
  9. luacgt1
    luacgt1 Forum Member
    wolverhampton
    first time i have noticed this car on here, i like it
  10. mk2sp Forum Member
    GREECE
    Cheers guyz.
    Maybe u r right. Rallye front end might fit better but i will need to remake new tubes for I/C and lines for oil cooler.
  11. mk2sp Forum Member
    GREECE
    Some progress took place on the car last days.
    Inner metal of the front and rear bumper were removed and bumpers were supported by Sparco fasteners.
    WATER SPRAY INJECTORS for the intercooler were added
    BATTERY was moved on the rear
    INSIDE totally stripped out and resprayed
    NEW DASH was manufactured as Digifiz was not compatible with the ECU
    ENGINE is ready and made 255 bhp@6,300rpm with 37 Nm@3,400rpm. Car's weight with fluids and half tank (19litres) is 870 kilos.
    02S GLB gearbox is ideally geared for track use with that amount of power. Car is pretty strong at the straight line and fair on the public bends with road tyres and KAAZ lsd. Inside the track, on 235/610/17 slicks is much much better with the KAAZ been very helpful.
    Next step, will try to find ideal suspension geometry for the track as caster on the front and camber-toe on the rear is easily fully adjustable now. Stronger brakes (4-pot maybe) and roll cage should be on the plan also.
  12. velly_16v_cab
    velly_16v_cab Forum Junkie
    Melbourne, Australia
    very nice build :)
  13. PAB
    PAB CGTI Regional Host
    Mansfield Notts.
    Liking your work, the car is lookin really good, glad its not all doom and gloom in Greece.
    Keep it up, lovin the quick release bumpers.
  14. mk2sp Forum Member
    GREECE
  15. Bundles Forum Junkie
    Aberdeenshire
    All cars should have bumpers fixed on like like that! great idea! :thumbup:
  16. Paul-R New Member
    I don`t understand the reason for doing this ? Does it stiffen up the rear ? I know Golfs don't have independant rear suspension, does this work in the same way as a big ARB ? [:s]
    Love the wide arches,makes it look purposeful :thumbup:
  17. George HH Forum Member
    Kent
    great build, top work :thumbup:
  18. Bundles Forum Junkie
    Aberdeenshire
    It stiffens up the rear beam, pretty much eliminating any flexing of it, which in turn keeps the wheel geometry/allignment from changing during corners when the rear beam is loaded up and possibly flexing. Gives a more taught consistant feel and will increase outright grip a bit :)
  19. thegave Forum Member
    London
    congratulations stelios, it looks fantastic.
  20. mk2sp Forum Member
    GREECE
    Thank you my friend :).
