how easy/hard is it to replace all bushes with poly ones on your own? What bushes do you use? Any links i should read? Ta mickster
Wish bone bushes are easy, I used prothane from a GSF kit (bought a kit s/h) OEM Beam bushes are a bit of a c**t to get out, but the 2 piece Polysports from Rally Design (11 each + vat + p+p) are easy to fit. - Literally just slide in,then tap the sleeve through the centre Make a lot of difference
Hopefully shall be fitting a full set of powerfelx front wishbone bush's during the xmas front end re-build Have fitted powerflex rears already, literally a 10min job perside max, once you know how to remove the original bush. Edited by: Andy947
do rally design have a web site? was gonna go for powerflex rear ones to fit over xmas, but if the polysport ones are cheaper and you reckon they're as good then i'll go for those instead. they're two piece aren't they? also, how'd you get the old ones out? drill loads of holes, then pull out the metal centre, then chisel the remaining rubber out? you also have to cut away the metal ring thingy on the rears don't you? i'm planning to attempt doin it without removing the beam completely as well!!
Rally Design website I got wishbones and rear beam bushes from them. They sent them really quickly. I havn't had chance to fit them yet, so don't know how hard it is. But the quality of them looks to be very good. I also got a powerflex anti roll bar bush for my front Eibach ARB. looks to be the best made out of the lot. The bushes I got with the Eibach ARBs seems to be a bit less well made, but again, havn't fitted them yet so can't say for certian. Edited by: wussel
All I can say is I fitted Powerflex Bushes all round, and I'd recommend them to anyone. Tightened everything up nicely and if anything the ride is better than standard rubber. If you want your fillings shaken loose by cheap poly bushes that's your lookout, personally I wouldn't go there.
I'm tighter than a duck's ar*e - No way would I pay 50 quid for powerflex beam bushes, or 40 quid or whatever they are for powerflex wishbone bushes These cheap bushes tightened up the handling of my car for little outlay, what more can I ask for? I've got an OMP race seat with no padding, fillings - what are they?
I'm fittin powerflex, only cos me old man is buyin them for xmas, and he is doesnt want to buy me cheap stuff, and it'll match the rear powerflex ones
well, i'm gonna go for the same as gvk i think...can buy a whole set for the same as buying just rear powerflex ones? gvk - are they two-piece?
right so the actual rubber of it is still one piece (unlike the powerflex ones if i'm right?) but its not a prob cause you squish it through easily then hammer the metal sleeve in place? any other tips?
As Andy says - You get the poly bush which replaces the 'metallastic' bush and the sleeve for the bolt. 2 pieces bush sleeve
dad has the polysport red ones, and there is no noticable harshness from doing the job, i wouldn't even dream of doing it without removing the beam
if i remove the beam, is it gonna be a biatch to undo the brake lines? (keep in mine my car is 10 years old!)
