Is underway Stripped off all the frotn suspension, wishbones, drive-shafts etc At a wee sticking point now with the tie rods..... But that will soon be overcome Pics to follow Edited by: Andy947
This is on the GTI The tie rods are a pain cos of the way they fit into the PAS rack, which prob means i'm gonna have to pull the rack out to fit the longer tie rods
Andy, cool. Pics when its done, should look nice and wide!! Paul, looks mint. Are those BBS RS or RZs?? They look like splits.
Actually a much easier way is to space the stub axles out I'm gonna do this, as the eibarc rear ARB wont fit a wider beam
Here's a couple pics. Passat spec Suspension gear being fitted, same width as the MK3 VR stuff, but has the correct ARB point on the wishbine for the mk2 ARB Not sure on the exact track increase, but it is around 18mm per side by the tech info on the track rod specs
I broke a passat ages ago - kept all this good stuff to be fitted at some point - and now is the time
Did the wide track on mine just a few weeks back, when i measured it was about 35mm wide each side on the front, i changed the wishbones (kept my poly bushes) and tie rods didnt bother changing driveshafts but seems fine so far... i spaced out the stub axle for the rear 10mm, couldnt be bothered changing the whole beam as i'd need different poly bushes, but an eibach arb would fit a wide rear beam!
Did you measure it blindfolded No dnager its 35mm per side - the track rods only differ by 18mm per side
