We have a stock of LHD spec' R32 MK4 / Cupra R aluminium throttle pedal trims to clear. The are for Left Hand Drive cars only, but we think they should be adaptable if you're motivated enough. 12.95 each, link to item on eBay here
It's for UK R32 so that it DWB. Paypal direct would be best sales@deutsche-parts.co.uk and we'll post it out. Cheers.
This is the Anniversary throttle Pedal cover with the round holes Going by the link its a cupra r part to start with They do look nice I have TT covers and r32 ones I could measure back of one for you Noel if it helps
looks like it is wider than the rhd one but this look like it makes ideal for fitting to the mk2 accelerator pedal just needs straightening a bit see like below http://www.clubgti.com/showthread.php?14816-TT-pedals-in-a-Mk2
Slight panic when warehouse guy came and said 'the box for those pedals is empty' Found them now, all packed and going in the post tonight.
We've sold a few of these, they're wider than a UK right hand drive cover and in the MK4 they catch the wheel arch carpeted area, but if you have more room around the pedal (as per MK2) then they should be fine. Cheers. Noel
Mine was delivered the next day so thanks very much Noel and Deutche Parts It is wider that the Heinz57 pedal I have. I'm sure I can fit a slightly wider piece of metal over the existing to make it fit. Thanks very much
Good to hear the Royal Mail did their job. These are going well, always interested to see how they go on models they're not designed for.
i have a few sets of pedal covers now i've had both TT and r32 ones on the 4motion the ones above being that bit wider fit the standard mk2 pedal with very little work the brake and clutch are the same shape on most vw and SEAT's you can see below the LH throttle pedal fitted the cover needs straightened a bit it looks like he used two clutch covers as the brake side bit is on the other side this save cutting the tab off the back of the brake cover i guess
