Rear spoiler wiring route
Discussion in 'Mk3' started by paulm2322, Oct 6, 2021.
  1. paulm2322
    paulm2322 Paid Member Paid Member
    Liverpool, UK
    Hi,
    I’ve just bought an oem rear spoiler with 3rd brake light. The spoiler is the same as the one on the car at the moment (three bolts through window).
    My question is does anyone know how to route the cable from outside to inside? Will I need to drill paintwork or try and make hole in glass?
    Any help much appreciated,
    Thanks,
    Paul
    theres an extra hole in the glass, not really viable to drill it yourself would have to take it to a specialist. tried to find a pic of the 4 hole glass but got nothing sorry
    paulm2322 likes this.
  3. paulm2322
    Liverpool, UK
    Thanks John,
    mill have a good look for 4th hole when I take old spoiler off.
    cheers.
    your screen will have 3 holes, 4th is on the 91-92 US spec only
  5. paulm2322
    Liverpool, UK
    That’s a shame. Looks like I’ll have to drill the boot lid.
    cheers
    wonder if theres scope to replace one of the studs with a hollow threaded thingy of some kind...
  7. PhilRyder
  8. dragonfly
    dragonfly Paid Member Paid Member
    Birmingham
    On my mk2 - I fed the wiring through the middle hole, then covered with a webbing sleeve. Either use a small grommet or silicon to stop any water leaking through. Routed the wiring along the upper roof trim and down the side to the bulb holder.
  9. paulm2322
    Liverpool, UK
    Thanks everyone,
    The new oem spoiler has 3m tape as well as the 3 bolts. Surely if I omit the middle bolt it would still be secure? That’s a good tip DF.
    Thanks for the advice.
    Paul
  10. paulm2322
    Liverpool, UK
    No idea how I would remove this bolt. Just had pliers on it hoping it would come loose but it’s not budging. Spoiler looks like it’s 2 pieces stuck together so not sure if I could unclip to get at the middle bolt:
  11. paulm2322
    Liverpool, UK
    See where it looks like two parts.
  12. paulm2322
    Liverpool, UK
    I’ve got a multi cutter with fine wood blade on it. Suppose I could carefully cut a square inch hole where middle bolt is and remove it that way?
  13. PhilRyder
    It's likely to be a T bolt which will prevent it from turning or coming out. If you go to mad you could ruin the spoiler.
  14. paulm2322
    Liverpool, UK
    That’s what I’m scared of doing [eek]
  15. PhilRyder
    I'd be tempted to buy the correct drill bits and make a hole in the glass. Go slow with plenty of lubricant and you should be fine. New or second hand screens aren't much money.
  16. dodgy
    Aren't the rear screen toughened? Not sure can drill that, all holes need to be in before toughening as far as I know anyway.
    PhilRyder likes this.
  17. PhilRyder
    Good point, well presented. Wouldn't stop me though :lol:
  18. dodgy
    If it was laminate it would be OK, such as a front screen with an airbag system in car.
    Used to be a hack (bodge) to stop cracks growing, drill a hole at the ends and fill with silicone.
  19. paulm2322
    Liverpool, UK
    Safer option might be drill small hole in hatch. Treat with anti rust then silicone. Spoiler would then hide drill hole? Load of hassle for me if rear screen pops as I start drilling [:$]
  20. paulm2322
    Liverpool, UK
    Sorted! Took plastic grommet out of hole and it has given me just enough space to tighten but without damaging cable! I will silicone the hole to waterproof when I’m done. I’ll post pic when it’s all finished.
    dodgy and PhilRyder like this.
