did you go into configerator to tell megatune what ecu ect it was? open megatune go file configerator set the code ect
if not then you need to do it or megatune will just get confused and not know what ecu version of ms and what code you are using
WELL, its running haha!!!!!!! its lumpy but it is running never the less !!! WOOOOOOOOOOOOOOOOO its still works on the 7.6 req_fuel thingy... not sures whats going on there but hey who cares. speak tomorrow guys. Scott
now i got well confused, the manual says timing should be set to the same as the trigger offset in megatune, which is set at 60Deg, if i have it on 60deg then it runs rough, if i move the dizzy so the actual timing (on timing light) is only 10 deg BTDC then it runs a lot better, but this isnt what it says to do in the manual........ whats going on ? p.s. it starts on the button without even coughing. woop woop But this timing thing is confusing me, i wonder, why the hell does it say set it to 60deg BTDC? To correlate with megatune offset, or am i missing something@?
Does your timing light have adjustable advance. 60 deg is the position of the Hall Sensor same as mine. When its running, what does the Megatune say ? 15deg . if so set the timing light to 15deg advance and move the dizzy until the timing marks line up.
Ah ive got you, so the offset is the actual hall offset not the timing... if you know what i mean,..... i get you now haha, so i should look at the ignition advance dial in megatune, then set the actual timing with the light to the same is that right??> I just got really confust as to what trigger offset is. i got it now. haha
it has got adjustable timing dial on the light, so i will do that later, im ****ed, went to bed at 3.30 am, still the mrs was in town what else was i meant to do??? wash up??? nah
yea i do, but i did the calcs online also and it gave 7.6 as upper req.... i have, 1984cc 440cc injectors simultaneous injection ?now i saw an old post of Trev16v which he said his req fuel was around 7, i'll pm him,
toyotec is your man he may even have a base map you can use least its running where theres a will theres a way
hi all, i'll have a look at alternating, gonna have a good play around when the looms is tidied out the way, i need a new dizzy and rotor arm too, and im putting in the isv too before i start changing anything else.... heres some pics anyway.... What a mess.... as you can see in the top left we tried a few coil packs haha Engine is sitting really high on the left, i think my brother has used the wrong mount, what mount should we be using??? Its an abf in a driver.. A pic of the car (ish haha) note the g60 steel with parada yoko 195 50 15's also got g60 brake set up, coilovers etc.... Cant wait, and its not even my car, ive just done the squirt
