no its like ETKA. the advantage of ETOS is its got a better interface and you can update prices from the internet. However it doesnt have the ATP feature. The workshop software is ElsaWIN
about 12gig, something along those lines. it could be the only decent info ill find for working on an S4. im hoping it tells all, including torque wrench stuff and part numbers for fluids etc
autodata isnt that fantastic as a workshop manual ive found. even something upto 2002 would suit me fine... ive found something though, i just need to see what if i can get it working
Elsa win isn't that good as a workshop manual. Doesn't tell you haw to do things like a haynes. However, it does have good wiring diagrams and has torque wrench figures and exploded diagrams.
Yes it does. But only if you enter the right way and click on the green icon after entering car details. Its got step by step procedures for almost everything.
mine is right up to date, the trouble with it is anything MK2 or older has next to nothing. even with the MK3 several early ECU diagrams are not included, only has post-95ish stuff. So no 2E code, no VR6 w/ ecu relay etc. As I say, its big! I just have VW and SEAT and its 14GB!
2000 S4 torque wrench trivia -------------------------------------------------------------------------------- you are allowed to cheat with a haynes manual water pump bolts stat housing bolts pas pump pulley bolts crank pulley bolts cambelt damper bolts lever bolts tensioner roller and guide roller bolts ribbed belt tensioner bolts ribbed belt guide pulley bolts vscious fan bolts the person with the most correct answers wins a toy
Got ElsaWin and 1.it was a PITA to install 2. Once installed it was a PITA to use. Pm me if you want to buy a PITA
I have autodata 2007 it's quite uesful, it has ecu pinouts for most things, torque settings, wheel alignment date, it also has a feature that lets you print vehicle specific service sheet etc, but have never used etka so cant offer a comparison.
Elsa win is ace...couldn't be without it! No corrado wiring diagrams on mine tho I noticed the other day
