... to space out 15x6.5 inch et35 wheels to the same outer level as a 9x17'' et 15 wheel? Want them to fill out g60 arches all round when im not going to be running my 9x17's for the new look...
6" wide wheel with 35mm offset would stick out 47.55mm 9" wheel with 15mm offset would stick out 99.3mm So you'd need to space out the 15" wheel 51.75mm or use a 50mm spacer. That can't be right!?? Someone slap me if thats wrong. I take it ET is in mm?? Edited by: harry_the_cake
My calculations match that website. You sure your wheels aren't 8x17 or something?? 52mm spacer is a bit big I would have thought. Edited by: harry_the_cake
50mm sounds about right Et15 9x17's are going to stick out a mile dont forget Where can i get good 50mm spacers from then?
Simply use enough washers per bolt to space it the required distance, no need to spend on expensive items that do the same job
Get some Beetle RSI rims, have you seen the offset of those, there must be 100mm or more behind the spokes.. lol
Jesus Gary, is this 'multiple post' day or somethign? I've got 20mm spacers.. wouldnt wanna go any further than that unless they're the bolt-to-hub jobbies, and even those are dodgy!
