Standard 92.8mm Stroke Eurospec Crank (From NEAL H) Standard Compression 10.5 : 1 Forged JE Pistons KR Head Gas Flowed & ported Head skimmed to the max adds 1 point = 11.5 : 1 Compression
Piston P*rn I have some pix of VW standard piston ABF, Wossner high comp, JE Standard Comp on there way to compare. Standard VW Pistion - pin to deck 21.46mm Wossner High comp - pin to deck 25.46mm JE Forged 10.5 : 1 comp - pin to deck 21.46mm
Which comes back to this thread here which Gurds put up - I don't think that thread did itself justice tbh
My Old Engine was standard ABF Bottom end with KR Flowed and ported head KR Cams 42mm inlet manifold . 170bhp @ 6200k 150lb/ft @ 3500k lovely engine to drive lasted me 10 good years
On Kjet? I'm a big fan of the mildly modified 2.0 16v - a great combination of power, economy, and reliability.
Brooky, can you post some comparative piston (with ring and pin) and rod weights? That would be interesting...
Forged from Premium 2618 aluminum alloy Dome and dishes feature smooth flowing radii for excellent flame travel. CNC Machined side relief with lower support band provides optimal strength for extreme horsepower applications. CNC Diamond turned skirts with reduced cylinder contact profiles provide less friction for increased horsepower Forced Pin Oilers for increased wrist pin lubrication Pin fitting, pin oilers and wire locks included Rings Sold Separately Pistons sold individually. JE Pro Seal Premium Piston Rings. The included ring set features a 1.2 premium steel top ring, 1.5mm Napier (hooked face) second ring and 3.0mm standard tension oil ring.
Neal ! Here you go ! Let me know if you require any more info. All weights are in KG's ABF Crank Standard 92.8mm stroke 1Y Crank Standard 95.5mm stroke i think ? ABF Eurospec Race Crank 92.8mm stroke (NICE) ABF Pistons Standard Wossner 82.5mm high compression piston JE 83.5mm forged piston 10.5:1 Comp (The best engineered ones i think) ABF Standard Gudgen pin Wossner Gudgen Pin JE Gudgen pin ( The best one too i think) ABF Standard Rod H - Beam Rod (Unkown manufacturer M8 ARP Studs) Integrated Engineering H-Beam Rod (M10 ARP Studs) The best H - Beam i think.
Just got a text message that my Microsquirt ECU c/w new loom is all complete and ready to collect. Its the first one he has done for Megasquirt but is quite impressed and has decided to fit one on his Porsche 928S V8. If anyone requires a loom making up please PM me and i'll send you Andy's details.
Good work So all in weights for the rod and piston combinations: Std ABF - 1,100 grms J.E + I.E - 1,020 grms Wossner + Anon - 986 grms 7.3% saving in weight for the J.E + I.E combination over standard, and a large increase in strength too. Nice.
Just looking at which type Fuel Pressure Regulator to use, i've been looking at Weber & i also already have a G60 FPR with a mounting bracket. What other options are their and waht does eveyone else use ?
