It's a good bit of kit Bill, can be a two man job to do tho, we had to drop the top mounts off and remove the front calipers to fit it in, you need an assistant to put a bit of weight on the wing as they're a bit flimsy. http://www.frost.co.uk/item_Detail.asp?productID=9108 Edited by: GVK
aha... yea, caliper.. will prolly have a go tomorrow weather depending on the dinked front wing I have.. already dinked so if I cock it up badly I need another one anyhows.
If any ones interested i have a mk2 widetrack kit complete with power stering rack from a passat all for 40
The passat rack is no use unless you are running a cable change gearbox as it has no mounts for the rod linkage
Question? Can you use VR6 wishbones, driveshafts and tierods to the same effect as the passat stuff? Note: want to keep it 4x100 stud pattern.
