Can you clean the Coolant expansion tank
Discussion in 'Engines' started by altern8, Apr 10, 2009.
  1. RIP-MK3 Forum Addict
    sunbury on thames
    use bleech and rice
    [:$] :lol:
  2. paultownsend Forum Member
    last time i asked for a mk2, it came at 28! mine had to come in the bath with me to get the rice out!
    all the dirt/sludge is out, the plastic is past it though
  3. funkbaron Forum Junkie
    New Forest/Southampton
    Yep, just checked ETOS, mk4 bottles (which I needed) are 9.32 +VAT but mk2 bottles are 29.45 +VAT (why the massive price difference I don't know)....worth jumping in the bath with afterall:lol:
  4. RIP-MK3 Forum Addict
    sunbury on thames
    don't they do the same job? can't they be adapted?
  5. Richard Mk2
    London / Bucks
    Thats true. I bought a new one from Gsf not long ago. Cost me about 20 :thumbup:
  6. G60Dub
    G60Dub Forum Member
    Angus
    Use long grain rice/wild rice as it absorbs the water at a lower rate and is easier to clean out.
  7. rubjonny
    yes the idea is to work quickly, dont let the rice absorb the water. i left mine in the corner and forgot about it, had to throw that one away :lol:
    altertnatively, get a MK4 header tank & cap from VW, chop level sensor plug off a car in scrappy. Much cheaper than a new MK2/3 tank from VAG and better cap, fits right on :thumbup:
  8. TheSecondComing Forum Addict
    I cleaned my Caddy expansion tank last night, and it worked a treat.
    Pillowcase - put half a bag of rice in it. Expansion tank - put the other half in it and the cap on. Put the tank in the pillowcase, tie it up nicely so nothing can get out and quite close so there isn't a lot of spare space, and wash at 40 degrees with biological powder. It looks like new now, but I expect will stain more easily in the future due to the abrasion.
    Did the same with a plastic chainsaw part, it had gone a bit yellow, and it cleaned up a treat as well.
    At your own risk if your missus finds out what that odd noise in the machine is.:lol:
  9. Admin Guest
    can you use the rise to clean the rest of the coolant system? :lol:
  10. rubjonny
    waterpump would mince it up, i imagine the end result woudl be close to risotto :lol:
    main issue would be it would completly clog the matrix, so you would have to bypass that.
    seriously though bio washing powder in the coolant system works an absolute treat
  11. G60Dub
    G60Dub Forum Member
    Angus
    Do tell regarding the bio washing powder in the coolant system trick...
  12. rubjonny
    well its easy really, drain it, flush with hosepipe to get worst o crud out, fill with plain water and cupfull of bio powder. run it till hot, allow tro cool, drain, flush. repeat as required :)
    works especially well at getting oil out of the coolant system if say you had an oil cooler failure
  13. TheSecondComing Forum Addict
    I'm going to write a book called "1000 uses for washing powder and ATF, courtesy of TSC".
    It will be published and I will make millions.
  14. paultownsend Forum Member
    how do you adapt a mk4 reservoir for mk2 fittment?
  15. rubjonny
    appaers to be a direct bolt on fitment for a 90spec header tank, got the idea off the corrado forum. the only difference is the level sensor plug, looking at it if you have a 90spec the pins from the old plug will clip right into the MK4 plug, but I've not actually tried this bit for myself.
    for a pre-90- it involves same mods required to fit a 90spec tank, fit 90spec bracket somehow then drop tank on, then solder MK4 plug onto pre-90 wires!
    clickity
  16. G60Dub
    G60Dub Forum Member
    Angus
    I can see the title now: Advanced engine maintenance: A litre of water, a bowl of rice and a pint of ATF. :lol:
  17. paultownsend Forum Member
    so the mk4 item slips straight into the mk2 bracket, and you just have to adapt the sensor plug? sounds better than spending an extra 15 on mk2 stuff!
    even a febi item is more than an oe mk4 tank
  18. rubjonny
    indeed!
  19. paultownsend Forum Member
    all parts 17.50 with discount! pick up tuesday :)
  20. paultownsend Forum Member
    completed this today. with a few new clips, hose and g12+, it came in at under 25!
    the brackett had to be modified slightly
