Cupracraigs MK2 GTI 20v
Discussion in 'Members Gallery' started by cupracraig, Mar 5, 2018.
  1. Savagesam
    Ah okay, I’ll bring mine home and have a play next week.
    I can paint my servo and fit my MC then [:D]
    What was the most common sizes you used?
  2. cupracraig
    South West
    loads of 10mm and 5mm, a few meters of 3mm. this wire loom has cost me a small fortune in replacement wires, terminals and braiding
  3. Savagesam
    But it’ll work and look the dogs when it’s finished
  4. cupracraig
    South West
    haha the sad part of that is that most of it will be tucked away behind pannels / chassis legs etc...
    but i'll sleep well knowing it was done properly..
    then when the engine dies, it'll get a nice TFSI unit
  5. Savagesam
    Annnddd then start all over again!
  6. cupracraig
    South West
    eat..sleep..loom..repeat
    i don't think it would be too much work to change to a BAM or similar unit, so that would probably be the way to go.
    the k03s and map on this sounding pretty nice though
  7. Savagesam
    I loved my mapped K03s car, was great fun
  8. cupracraig
    South West
  9. cupracraig
    South West
    Just updating my Jobs to do:
    • Extend the loom for the ignition amplifier
    • Run the battery cable and identify the place to secure the junction box and Battery
    • Install the engine for final loom position testing
    • Power it all up and check for wiring errors
    • braid the wires to protect them where possible
    • make new routing for wires
    • Install the dashboard
    • Secure all the cables in place
    • Fill with fluids (oil, coolant)
    • Run the engine, inspect and check for codes
    • Re-install the remaining interior
    • Re-install the remaining engine bay components
    • Buy and install a new front window
    • install dash loom
    • Make a new loom for the guages so that the lights come on when sidelights are turned on but the guages power up from ignition live. They are all on Ignition live at the moment
    • set up VCDS for logging
    • install n/s driveshaft
    • Install o/s driveshaft
  10. cupracraig
    South West
    Just had a go at putting a small guide together. its terrible i know, but its a start.
    its rough
    dodgy and Savagesam like this.
  11. cupracraig
    South West
    @rubjonny i think i asked before but i can't see where... but i have the Battery live wired to the starter, can i also hook on the Alternator wire to this too or do i need to go direct to the battery?
  12. Savagesam
    They’re usually daisy chained anyway aren’t they?
    cupracraig likes this.
  13. rubjonny
    for the mk2 and mk3 thr alternator cable goes to the starter, mk4 it goes to battery so whatever works for you :)
  14. cupracraig
    South West
    perfect, thanks guys! straight to the starter it is then :)
  15. Mk2daz
    Good progress mate, liking the to do list and the youtube video!
  16. cupracraig
    South West
    worth documenting it i recon. I'll go into more detail on specifics in new videos over time
  17. cupracraig
    South West
    I took the N/S wing off to see how i could do some routing of the lighting loom and i'm thinking about how i can freahen up the arches / protect them some more.
    I was thinking about using some UPOL Raptor in Black on the back of the wings, in the arches themselfs and on the parts of the chassis legs that dont see the light of day.
    It would freshen it all up in there a little..but i probably could not paint over the current sealant in the arches.
  18. davkav
    Ireland
    You could easily cut a hole in the side of the cabin and have the headlight loom run out from the fusebox and forward inside the wing. Would you want to cut a hole in the cabin though ?!
  19. cupracraig
    South West
    i'll probably go down the original route of going through the chassis leg, the hole is already made for that and the Engine ECU loom goes through there
  20. cupracraig
    South West
    Engine bay is looking a bit neater now
    I put in the dash last night to check the cables are doing what i wanted...and all looks good so far
    Starting to feel like a car again
