equal length drive shafts on a mk2 golf by adding a drive flange extender to the gearbox much as quaife do or as the rally has with it transfer boxes i am thinking of making a extender and was wondering if anyone has tried this
It will reduce torque steer significantly. Good idear BTW thought about it many times myself so would be interested in seeing which route you take, please post your results.
I thought you'd need an equal distance from each output cup, which would mean offsetting the gearbox. Just adding a spacer doesn't mean the distance will be the same will it?
yes 9.378" will need some support hear is a picture of extension shaft for QUAIFE 32G 6-Speed Sequential FWD Gearbox at almost $900 not cheep and not a good photo cant make much out the box for the t5 looks intresting
Would be very interested to see how this is done if it can reduce torque steer. Get masses of this and sure this is a cheaper option thann LSD.
http://en.wikipedia.org/wiki/Torque_steering http://quaifeamerica.com/differentials/diffs.htm http://en.wikipedia.org/wiki/Limited_slip_differential
So what your saying is that although equal driveshafts is of benefit, I will still get torque steer when I put the power down if I have about 280 bhp. But equal driveshafts will do nothing for me in the corners, hence the LSD? Thought this could be a quick fix to an annoying problem. Many thanks for the education
The equal length driveshafts will 'help' but certainly won't cure the torquesteer, especially with 280bhp. The stock VW driveshafts are 'tuned' to remove the torque steer inherant in thier unequal lengths at stock torque figures, as soon as you increase the torque output from the engine then you move outside the shafts design criteria. An LSD or TBD will make the biggest impact on torque steer.. Out of interest, I have a 02J gearbox with a quaife TBD and a ford galaxy layshaft and equal length driveshafts... I've found the biggest cause of torque steer in the modified VW community comes from people running low offset wheels without altering the theoretical kinkpin axis to suit...
