If anyone is interested in buying megasquirt to use with 20vt or 16vt engines i can supply with base maps and looms where needed its a cheaper alternative to EMERALD, DTA ,HALTECH, if anyone wants more info contact me through pm
You can have as much power as you want. MS will run a 20 cylinder engine (if it existed) at up to 20,000 rpm. It is fully programmable, 12x12 fuel and ignition maps plus enrichments, plus nitrous, launch control, boost control etc etc.
megasquirt well all being well i should be at no rice in feb with it as for the wiring is just a case of finding the right 12v feeds as some are switched via the ignition then splicing your sensors into the ecu ive known some people wire a ecu up in 2 hours i wired mine myself without to many problems as long as you have a multi meter a haynes manual your good to go as for mapping it is possible to map it yourself with somone driving the layout of the megatune allows even a novice to do it but you must read the tuning manual first
megasquirt If anyone is interested i will be at no-rice febuary with the car so you can see for yourself that this is a cheap alternative to other systems and in some respects better
dont quote me on this but i dont think it matters if you have it wired up or not the best person to ask with that question is toyotec from what i can remeber people normaly opt out of the vvt not sure why
so whats is the difference and what is the gain over, say, a standard ABF ecu? does it simplify stuff and allow more flexibility and hence power?
for cost look at how much DTA EMERALD AND HALTECH there close to 1000 and more where as the megasquirt comes in at a lowly350 and that is with a basemap to get it running from there on you can map it yourself as long as you have a wideband or you could get toyotec to map it for a fee most places that map on a rolling road charge 300 plus where megasquirt can be road mapped the difference between the abf ecu is that you do have the flexability to run boost control nos and it could be mapped to within an inch of its life if you wanted so with your abf if you put bigger injectors or a turbo on the engine what would you do about mapping the digifant ecu ?? take it to revotec or formula one they charge you 300 to map it with the megasquirt you can chop and change things as you like so bigger injectors you just tell the ecu you have more fuel now obviously there is alot to learn about megasquirt but the way i see it the more you know about how your engine runs the better theres is so much information on how to map megasquirt it really is worth going down the cheaper route sometimes for to long now people have been put of having the engine they want due to the cost of the ecu but now thats all changed megasquirt will truly run what ever you want
for example, my abf has a 'blitzchip' chip in the ecu. i have no idea whether its a good or bad map, but if i go to MS, is it likely that ill be able to get make the engine run better? how clever is it, for example, with knock sensors? in fact, im gonna go look for a website for them, see what can be controlled
The real reason for offering this option with megasquirt is because so many people have bought a megasquirt from a supplier who doesnt know there needs which then causes huge problems for the people fitting then there are many different variants of megasquirt and it fustrtes me when someone is struggling only because they didnt get what they needed i spent nearly a year getting my ecu to the point of completion and now i have theres no reason why other people shouldnt be able to get the same setup as mine its been tried and tested we know what what the ecu requires to run the 20vt and 16vt so were just offering a easy solution thats cheap with minmal fitting hassles it may be that this will become some kind of plug n play system in the near future
i think toyotec will agree the megasquirt does run the 20vt extremely well and the best bit it is the americans still aint managed it at the moment were not using the coil on plugs with the engine as there are issues with them anyway but hopefully toyotec will resolve that in the near future im using the a 306 coilpack with 16v leads which doesnt look to out of place
megasquirt is well established you can buy a basic ecu built or in kit form involves lots of soldering what were offering a ready built unit with a base map and loom if needed and the support there is a forum for the megasquirt take a look at the problems people have encountered many of them have built the ecus or bought them pre built and still have problems were just trying to cut the hassle out of it for you with a setup that works well for your engine type all you have to worry about is fitting it which isnt that hard
