MK1 GTI 1.8T 20v 25 Year Project
Discussion in 'Members Gallery' started by Brookster, Jan 4, 2009.
  1. Brookster
    M1 J40
    I think i'm just gunna pot a row of 38mm holes across the front , and another row across the rear on the bonnet with some Black mesh glued on behind.
  2. Brookster
    M1 J40
    Here's my GRP Bonnet before I cut the holes in it, also need to cut out the air vents at the top.
  3. mitlom
    mitlom Forum Member
    Ripley, Derbyshire
    Going back to the front crossbrace.....I cut the box section out of a new front panel and fabricated a new cross member instead on the racecar as I was having to replace the front end due to a shunt at Brands, I'll try and dig some photos out and get them upl
  4. Nige
    Nige Paid Member Paid Member
    That`ll help radiator airflow.:thumbup:
    I don`t see the benefit of this. It`s a high pressure area. [:s]
  5. Brookster
    M1 J40
    That's for when the car is stood waiting to race , to get rid of the heat prior to a run .
    I don't always have the pit crew (Wife & Kids) their to drop the bonnet when I get to the front of the line up. GTI Festival was a right pain for that reason .
    I don't mean right at the rear , I mean 3/4 back before the high pressure area.
    I do run Evans Supercool 180 so the Engine does run hotter than normal , I also need to fit a fan override switch in circuit too to help matters.
  6. Brookster
    M1 J40
    The hole positions detailed below for a rough idea
  7. Nige
    They aren`t even equally spaced ! Rich, c`mon !!!
  8. Brookster
    M1 J40
    that was on my phone I don't have fancy design software [:s]
  9. Nige
    Ah, I thought you`d marked the bonnet ;)
  10. mitlom
    mitlom Forum Member
    Ripley, Derbyshire
    This is what I did for my cross member ;)
    3mm plate bent to form a 'u' section and then welded to chassis legs, then 2.5mm wall 50x50 tube welded under these with end caps welded on as well. a 3mm plate was then dropped down from the square section tube and front portion of JMR front mount was welded directly to that :thumbup:
    Brookster and pascal77uk like this.
  11. Brookster
    M1 J40
    Nice one
    Need to get some made
  12. Brookster
    M1 J40
    Just spotted your alternator bracket , did you make that too
    Could do with one like that
    Cheers
  13. mitlom
    mitlom Forum Member
    Ripley, Derbyshire
    You mean the rose jointed one to top of alternator?
  14. Brookster
    M1 J40
    Yep the rose jointed one :thumbup:
  15. mitlom
    mitlom Forum Member
    Ripley, Derbyshire
    McGill motorsport M8 turnbuckle and a pair of LH & RH thread rose joints is what you need, just work out what length you need and go from there :thumbup:
    jamesa and Brookster like this.
  16. Brookster
    M1 J40
    Fitted the Cross Brace that finally arrived from the US
    Wish I had made my own now and welded it in place .
    this one bolts onto the bumper mounts but i'll be welding it too .
    Front Panel bent with the strain
    Cross brace fitted
    loads of copies for sale Mr Snitch so you can go running to your friends in the US :p
    BUT IMPROVED DESIGN
  17. Brookster
    M1 J40
    Turn Buckle and rose joints also ordered for the Alternator
    mitlom likes this.
  18. sambo Paid Member Paid Member
    Good stuff Brooky :)
  19. Brookster
    M1 J40
  20. mitlom
    mitlom Forum Member
    Ripley, Derbyshire
    No but the ones I have on the racecar are similar and tbh don't work that well as the upper spring platform fouls the inside of the mount without me making a spacer up to give needed clearance. I am in the process of designing my own on CAD and will then be getting some made ;)
