right well ive looked around two scrappies now ive found out that so many cars have similar sunroof motors as the passat/senater one basically all of the sunroofs have the same fitting as the seneter one pictured earlier the screws are alot wider apart so you will have to drill to get them to fit but the later audis have the same fit some volvos mk3 golfs (i think) seat's some pugs alfa's etc etc buit they are all different in shape and desighn there is a passat with one ion in the scrappy but i dont know if i lkike the drilling idea so much anyway the audio 100 seems to be one of the only cars with the smaller same fit as the golf so to do no drilling you will have to find one of these however you should be spoilt for choice if you want to fit the wider size one. also i think the cover on the audi 100 will fit the golf with a little re trimming not sure tho as i havent put them together yet. anyways back hunting for me
You doin a leckie sunroof too??? My 15 complete Scirocco T&S sunroof turned up yesterday Im thinking of doing an electric T&S now......
I've found out what your switch is off.... A MK1 Cabby with a hydralic roof, I was at the salvage auction today and the roof switch looked exactly the same. I tried a audi 100 cover but it was the wrong shape I'm sure it was either too short or not wide enough also it is desinged to fit the contours of the Audi roof. Edited by: Jetta
yeah should be, If you could get a wiring diagram for the switch you'll be laughing. The car was an 89 Clipper, if that helps with getting a wiring diag.
Cheers. Harry_the_cake was supposed to be doing a diagram for me but i dont think he has been on here the last few days........
Damo> where you get the t&s roof for 15 from?...lmk if you can get any more as I 've been after one for ages....
Damo, heres the wiring diagram I promised. Sorry it took so long. Work and all that [:^(] Here ya go. Should be pretty self explanatory. The ones marked "M" go to the motor. The polarity on these switches over as you press the switch back and forth. Just swap 'em over on the motor if it winds the wrong way.
Just realised the green ones are not clear. They are "-12v" or earth, depending on what you call it. Edited by: harry_the_cake
