16VT mk1 GTI content.....GT3071 inside
Discussion in 'Members Gallery' started by Marsrot_16v, Sep 26, 2009.
  1. Marsrot_16v Forum Member
    Norwegen
    Pretty new into this forum,and thought I could make myself a bulid thread in here too...:)
    The car is a early 84,sold new as a Rabbit version with a minimum of equipment :p
    So I thought some extra parts should do it,maybe a 16v with turbo++?
    From the starting point,a dirty and worn 16v PL engine:
    Cleaned block and cylinder head..
    Painted,soon ready for assembling..
    H-beam rods with ARP2000 bolts,JE pistons 82,5mm and Sputter bearings..
    Upgrade Stage 1 finished,now over to the cylinder head..
  2. Marsrot_16v Forum Member
    Norwegen
    ABF 2.ltr head,raceported but still with original valves & springs:
    Windage tray from TDI..
    Also got made a SS316 echaust manifold,I made myself a jig here..[​IMG]
    In production @ mr.Nedregaard
    Finished welded, and strapped with exhaust band..I later found a turbo without wastegate,so more piping was needed..[8(]
    A new and simple intake manifold had to be made,so I designed som drawings in my head a late saturday evening, and got it started..
    Chop,chop!Later I glassblasted it to make a clean and good welding..
    Rolled some pipes into the exact dimensions of the intake flange,and spot welded..
    Bottom plate made..
  3. Admin Guest
    nice looking project!
    you state side then if its a rabbit? any pics of that?
  4. Marsrot_16v Forum Member
    Norwegen
    Thanks,more pics to come..:)
    I dont have old pics of the car,the only things I have left of the rabbit parts is the side mirrors and the rear hatch badge :) heh
    But how come it takes many hours before I post a new reply to it appears on the thread? Does it pass the moderators before it get posted here?
    Yes, just spam prevention :thumbup:
  6. Toyotec
    You LHD boys sure do have the space for have equal length tubes and even a decent sized downpipe.
    What thickness are the manifold tubes?
  7. Marsrot_16v Forum Member
    Norwegen
    Hi, I`ve never thought about that befre though...And there was more room when the 020 gear levers was cut away..
    I think the tubes was 2mm thick, 42mmx2 :)
  8. Marsrot_16v Forum Member
    Norwegen
    Ohh,thats okey..But why cant I edit my own posts?
  9. Marsrot_16v Forum Member
    Norwegen
    Finished...Only needs some grinding inside the runners..
    Now over to the gearbox..
    The intention was to use a orginal Corrado 02A transmission,but I got hold of a AFF gearbox from Passat TD that I will use instead.This has shorter 1-3 gears than the Corrado trans,what is perfect for track use..The 4/5 gears are longer,and good for top speed :)
    I think this has rounded soon 400t.kms [:D]
    Dismantling..
    Overhauled and reassembled gear mechanism..Made new bushings in nylon,but think i will make new ones in brass..Or do I get better ones for these?
    Cleaning and glassblasting..
    Peloquin differential with VR6 ring/pinion 3,39:1 with final ratio..
    Finito :)
  10. Admin Guest
    you should be able to, you are now free to post away with out need of moderator approval..
  11. Marsrot_16v Forum Member
    Norwegen
    Thanks man :)
  12. A.N. Other Banned after significant club disruption Dec 5th 2
    What are the ratios out of interest?
  13. TurbTech Forum Junkie
    London
    Nice work man :thumbup: Love how the amount of work/fabrication that is needed to build a 16vT means that every project is different to the others. Keep us updated [:D]
  14. Marsrot_16v Forum Member
    Norwegen
    Here you go,in comparison to the VR6 CCM trans :)
    AFF 02A(From 1991 Passat 1.6TD)
    1st Z=34/9=3,77:1
    2nd Z=40/19=2,105:1
    3rd Z=39/29=1,344:1
    4th Z=34/35=0,971:1
    5th Z=35/44=0,795:1
    CCM 02A(VR6)
    1st Z=33/10=3,300:1
    2nd Z=35/18=1,944:1
    3rd Z=34/26=1,307:1
    4th Z=30/29=1,034:1
    5th Z=31/37=0,837:1
  15. Marsrot_16v Forum Member
    Norwegen
    Thanks for comments :)
    Will post up some more pics here..
  16. Marsrot_16v Forum Member
    Norwegen
    Also needed a clutch kit..Spec 3+ with alu.flywheel,carbon/kevlar disc and strengthened pressure plate
    Got the engine and trans back together and thrown it back into the car, but had sold my T3/T4 turbo so I was in need of a new one..GT3071 it is ;)
    As for the engine management speaking,I am running a Haltech E6X on this one..The first plan was distributor ignition with MSD 6A and Blaster SS coils.But when I found out that I could use later 1.8T coils with some slight mods this was a factum.These coils also have built-in igniters.
    Some wiring pics..
    I am using a 60-2 crank sensor from VAG,mods was also needed for this one :)
    So when I ordered a new turbo,I also needed a wastegate. Tial 38mm..
    More piping...
    I am running a 3" all the way back to the rear beam axle, with Magnaflow resonator and Borla muffler in the back..
  17. Marsrot_16v Forum Member
    Norwegen
    Now over to the car.I bought it two years ago and has a low mileage with only 88.000km on the meter..:)
    Anyways,I had to tear it apart..And back in with a new original front plate..:)
    Finish welded...But I have more work to be done..
    Rusty spots..
    2-component primer..
    Stopping power.. 305x28mm with Brembo 4-pots, these are from Cupra R..With custom caliper brackets.The rear brakes are original 16v discs..
    New KW variant 3 suspension..
    Compo MO 8x16 with 195/45 rubber..
  18. Marsrot_16v Forum Member
    Norwegen
    I had to try it with the fenders and hood on..Looks like it needs some more spacing at the rear :)
    Mounted oil cooler and the custom IC..
    Ohhh, I cant forget this one...;)
  19. Admin Guest
    love the wheels!!
  20. vwaudi Forum Member
    Wolverhamptons finest.............
