DTH Jenveys with 120mm trumpets which air box/socks
Discussion in 'Throttle bodies & non-OEM ECUs' started by altern8, May 18, 2010.
  1. altern8 Forum Junkie
    Cocos (Keeling) Islands
    Hey
    Just wondering what socks/airbox will fit a mk2 using dth jenveys with 120mm trumpets?
    Cheers
  2. Brookster
    M1 J40
    RAMAIR 13 ON EBAY
    5 FOR FILTER OIL
  3. altern8 Forum Junkie
    Cheers,I got some Piperx socks but they look like a poor fit and are very tight with the trumpets mouth
  4. altern8 Forum Junkie
    These ones
  5. Brookster
    M1 J40
    Yes :thumbup:
  6. altern8 Forum Junkie
    Cheers, I'll order some of them were they tight around the trumpet mouths?
  7. Brookster
    M1 J40
    Just cut them but they are also better with some wire mesh putting at the fronts so the middles ren't sucked out :thumbup:
  8. chrismc Forum Junkie
    Them piperx individual foam socks are rubbish. Had them on my itb'd mk2 and they fell to bits...[:^(] I went for ITG after that and they were far superior.
    I don't think that design is best for power either compared to a large dome filter (if you can make it fit). Remember reading it somewhere...
  9. Brookster
    M1 J40
    i can't fit a Pipercross P600 dome filter under the bonnet,with my TB's
  10. altern8 Forum Junkie
    My Piperx ones have already started to tear slightly
  11. Brookster
    M1 J40
    ADE's MK1
  12. badger5
    nr Glos
    i ran ITG single filter socks.. they would last about a year before getting too rough and crumbly, about 15/sock way back when i used em
  13. Brookster
    M1 J40
  14. altern8 Forum Junkie
    out of intrest how do smaller trumpets and a airbox fair?
  15. danster Forum Addict
    If you can get a big airbox fitted all the better. If you look at the Lehmann engines in Golfs and Seats, they use a massive volume. Think it is something around 30litres of volume they use IIRC. They still have long inlet tracts though.:thumbup:
  16. altern8 Forum Junkie
    Blimey they are huge
    I found this sort of setup too
  17. altern8 Forum Junkie
  18. RobT
    RobT Forum Junkie
    Cheshire
    thats the pipercross 600 airbox with some sort of recessed backplate to try and clear the fuel rails - some do, some dont
  19. Brookster
    M1 J40
    Ah, they are like the one I have. As mentioned, the guy making them originally passed away, but if they're on the website now (this was years ago) they may have re-created them. There's the undrilled offset backing plate, needed depending on trumpet length, shown on the same page.
    Bonnet clearance will still be your main issue though.
