"A" vr6 Yank MK2
Discussion in 'Members Gallery' started by afbiker02, Apr 13, 2010.
Tags:
  1. Toyotec
    Plus the "talks" to make it a real 8v FTW.
  2. afbiker02
    Bury St. Edmunds
    How do I make this happen?
    Edit: I understand what your getting at Toyo ;)
  3. Dave
    Sligo, Eire
    Here's your manifold Lee.
    The broken stud!
    I managed to get it out eventually thanks to some tiny burrs that Justin (Mushy) sent to me and a fine pointed chisel. Spot the deliberate mistake?[8(]
    Hope the other studs come out OK with just a bit of gentle persuasion?;)
    Sorry Lee but I don't have a downpipe for you.[:^(]
    dont worry too much about those studs, they arnt needed on an abf. or a kr really, only to hold the shroud on for warm air feed and it does bugger all in the uk on an injection car anyway
  5. afbiker02
    Bury St. Edmunds
    Cheers SDa, Now I can get a down pipe so I can put all the pieces of my exhaust on.
  6. Dave
    Sligo, Eire
    Hey up John! What's all this dirty talk about abfs and krs? It's an 8V manifold for Lee's proper solid lifter EV motor! As if I'd touch nasty valver stuff?[:x]
    PS. I don't care if the studs are not required, I'll still get the old ones out and fit new ones! ;)
  7. afbiker02
    Bury St. Edmunds
  8. rubjonny
    sorry i thought you were binning off all your 16v rubbish for the new project :lol:
    your ocd is showing [:p]
  9. afbiker02
    Bury St. Edmunds
    The old blowing exhaust is gone. I got around to fitting my new exhaust yesterday...mostly. I was going to just fit the 2 rear boxes as they were blowing very bad. I had them off in about 30 minutes, then decided to take the heat shield off and install my last 2 harness mounts. Not fun and a little difficult by myself. I drilled the holes just a few mm too low but there in and I'll have my harnesses for Curby[:D] Put the heat shield back on and was thinking this will be quick...yeah not really. he down pipe and the first silencer pipe were the same size[:x] after a lot of streching I got it to fit, by a few mm[eek]. Today I went back to the shop with the first silencer to fit it properly. The previous owner of my golf had removed the original first silencer and replaced it with a peice of scafolding then reattached the down pipe. So today I cut off most of the down pipe to this
    [​IMG]I removed the last bit of scafolding before I installed the first silencer
    then attached the rest of the exhaust
    No more exhaust leak[:D] The wife, mother-in-law and neighbors will be pleased
  10. Dave
    Sligo, Eire
    3 Studs out - 5 Studs sheared - 2 Studs untouched:thumbup:
    But:
    The bloody thing is no good. It is cracked![8(]
    Sorry Lee.[:^(]
    Hopefully someone else has a good manifold?
  11. shaz8389
    shaz8389 Forum Junkie
    I might have an 8v manifold off a PB you can have for beer tokens.
    Of course I'm rubbish at postage so we'll see.
  12. afbiker02
    Bury St. Edmunds
    Cheers Shaz, just let me know what kind of Beer you like.
  13. afbiker02
    Bury St. Edmunds
    Too bad for that crack, but don't worry CGTI has come through again:thumbup:
  14. rubjonny
    im sure it'll be fine with the crack, you cant see any soot staining. pretty much all 16v manifolds are cracked but they dont leak
  15. afbiker02
    Bury St. Edmunds
    Cheers for that RJ. SDa if you want to send it over still I'l be greatly appricative.
    Here a little video of my time around curby
    [YOUTUBE]58eUEkyCEU0[/YOUTUBE]
  16. Dave
    Sligo, Eire
    If you say so John!:thumbup:
    But a delay is at hand![8(]
    http://www.clubgti.co.uk/forum/showthread.php?t=241610
    Why do you keep mentioning 'Dark Side' engines?[:s]
  17. afbiker02
    Bury St. Edmunds
    I want more power but at the moment I dont have the money to build my EV up, so I figured do a swap then build up the EV and swap back at some point
  18. Dave
    Sligo, Eire
    HANG ON!
    Are you now telling me you are going to the 'Dark Side'?[:s]
  19. afbiker02
    Bury St. Edmunds
  20. Dave
    Sligo, Eire
    No, I had not![:x]
    And you expect me to spend hours Dremmelling studs out of an 8V manifold for you?[:s]
    I should CoCo!:lol:
