so far on the list: http://cgi.ebay.co.uk/K-N-AIR-FILTE...VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247 http://cgi.ebay.co.uk/ws/eBayISAPI....m=320121001605&ssPageName=STRK:MEWA:IT&ih=011 http://cgi.ebay.co.uk/ws/eBayISAPI....m=250237675938&ssPageName=STRK:MEWA:IT&ih=015 http://cgi.ebay.co.uk/ws/eBayISAPI....m=130192598475&ssPageName=STRK:MEWA:IT&ih=003 and prob that mk4 shifter! LOL Wife will have a fit!
thats the wrong light for a gti, they have a separate bit for main beam. as for the filter, mine came with a k&n which was rubbish (ie big hole, 1mm across, its meant to be a filter ffs) so i replaced that with a pipercross. id recommend pipercross or a paper one. the chip works well. not sure id spend a lot of money on wheels, its hardly like you gain anything and 16 inch rubber is not cheap at all lol what are your plans? (cant remember if youve said this already?) if you want to make a quick fun car, shell out on suspension stuff first
okey dokes...no plans as such, simple stuff first...make a nice decent example... have to have a look for a gti head lamp...shoudln't be to difficult to find... mk4 shifter right????? will get a piper cross induction kit then or filter....prob just the filter tbh....... will get the chip.... prob go poly bushes all round first service too..
just get the panal filter, the cone breathes tons of hot air bushes will need to be done i expect. theyll be shagged after all these years. well worth the effort!
some people on here have said they got a poly bush 'kit' for about 100 that did everything, do you know where to get this kit as on the website its all individual and would cost a fair wack more than 100 if you bought them all....
speak to rallydesign or one of those bugpack/gsf ones from ebay (prothane) with those mk2/mk3 kits you need to mod the subframe for the bushes to go in.
oh.... erm. track control arm front and rear. rear beam pretty much have to be powerflex poly rear top mounts are nice too i got normal rubber front top mounts tho
might grab some poly top mounts if they arn't too much been spending loads lately, 4 weeks before I go on holiday the missus aint to happy about it lol
well we bought it!!! 1800 (wouldn't go any less!) Well pleased with it... basically need to rip the lens protectors off (easy it seems) but needs a new headlamp....but do like the two light lamps... what are they called? hella cesis or something????? are they just bolt on? bad rust patch on the door sill on the passenger side (does everyone get this?) will get this fixed....how much do peeps think? cut out job i presume? and small spot of rust on other door under mirror otherwise its bloody spotless bodywise!!!!!! its a minter... interior is spotless, just small amounts of wear on the plastics...but for 12 yr car.... it managed 35mpg on the way home on the A50 and about 30-32mpg on the twisties with some overtaking and booting! not bad i don't think! 53 to fill it from empty too...not to bad!!! Will get pics up tomorrow.....but a real minter... should i rip the mud flaps off too? full closure alarm too!!! bargain! Rich
just vag.com it and came up with a knock sensor intermittant fault...will see if it comes bcak.... where is the knock sensor...
yeah rust on the sill is a PITA... Im doing a home repair due to it not being seen that often and it being a track day car, depends how bad it is regards cost for repair from a body shop, 100 - 150 as a rough guess. MPG sounds healthy which is good too!!! pics pics pics!!
yeah will get pics once its cleaned and polished! just sorting out front lights what to get and also rear cracker hella light.... need to get that sorted.
cracked rear lens? should be able to get a replacement from a scrappy for little money - loads of 8v mk3's in scrappies for some reason...
