Cordless Impact Wrench - Anyone got one?
Discussion in 'Tools, Equipment & Fasteners' started by Mike_H, Aug 22, 2007.
  1. G60. Forum Member
    Seychelles
    just squeeze some KY in
  2. Supercharged Forum Member
    Steve - Makita do an SDS drill lube, it's cheap and comes in a tube from Screwfix - this is what my mate uses on his which makes sense as they are similar weapons...
  3. Paul_TDi Forum Member
    I just bought a cheap 55 incl pnp one off ebay, 24v, 320nm and 1/2" drive.
    Had a pig of a job last night that kept me up til midnight in the front garden where I could of done with a impact gun.
    I'll take it to the scrap yard and see how many bolts it will undo!
  4. pigbladder Forum Addict
    cambridge , uk
    is it oil or grease? i was hoping i had something in stock already
  5. ryanp Forum Member
    just bought one of the 12v machine mart jobbies, 23 inc. the dreaded
    It's undone every bolt i have tried so far, including the suspension lower bolts which i found a pig before, with a half flat car battery!
    I'ts not amazing but easily saved me half hour of messing with rachets and breaker bars.
    Well worth the money in my eyes
  6. benlg81 Forum Member
    hi
    just seen a 12v impact gun and wondered if it would be ok for buzzing up the top nuts on the suspension
    Hi
    Specifications:
    Power Source: 12V cigerette lighter plug or battery connector
    Output power: 96W
    Cod length:4m
    Sockets: 2 double ended socket covers 17mm 19 mm 21 mm 23mm nuts
    Loosen/Tighten one button control
    3 digits torque display and settings
    Max Torque: 350N*M (258 ft*lb)
    can have the torque adjusted to specifics
    its just to tighten the top nut on the suspension that requires a allen key and a socket, as the allen key bit is partially rounded so just wantefd to buzz it up
  7. A.N. Other Banned after significant club disruption Dec 5th 2
    Do it up by hand as far as possible, and give it a very brief trigger pull to nip it up.
    Generally, it's not good to risk damper stems spinning inside the bodies.
  8. benlg81 Forum Member
    i have done it by hand as far as possible then the allen key rounded so thought a quick blast on a impact gun might help
  9. PNG
    png Forum Member
    In case anyone's looking for a cordless, Auto express's last comparison came up with a Maplin (!) one as best buy
    Also two previous comparisons: March 06 and Feb 08 - a couple of 12V corded ones in there too
  10. tshirt2k
    tshirt2k Forum Junkie
    Herts
    maplins price is 10 dearer than what they list.
  11. PNG
    png Forum Member
    ^ Doh!, autoexpress reviews create a lot of sales, so maplin obviously cashing in [:[] oh plus a bit more VAT now i spose...
  12. benlg81 Forum Member
    i only really need it to do the top nut on the suspension that has a rounded allen middle.
    i have to get it off as the spring has moved off the top cup now so need to get them off and sort this weekend
    will it spin off the nut?
    the torque looks ok to me
  13. benlg81 Forum Member
  14. PNG
    png Forum Member
    Something that might be worth trying is if youve got any torx / splined bits, you might be able to get one to hold in the allen socket. Don't know about the impact wrench but notice there's no torque figure quoted...
  15. tshirt2k
    Herts
    Had the same problem when trying to remove the shocks from my car. As i was changing them i HAD to use stilsons on the shock tube and alot of downward force. The only way it would budge.
  16. benlg81 Forum Member
    will that not damage the shaft
  17. benlg81 Forum Member
    hi
    finally settled on trying
    Clarke CIR13C " Impact Wrench Kit (12V)
    found some good reviews so worth a punt if not I will try the grips on the bump stop to stop the piston part spinning.
  18. benlg81 Forum Member
  19. Mike_H Forum Addict
    Mine too... maybe lost a little bit of power, but it's about two years old. Probably another year left in it before it shakes itself to bits.
  20. steved Forum Member
    Ive got two, A MAc tools 24v and the Snap on 4850, The Mac gun is like a kids toy compared to the Snap on. :thumbup:
