Please help my G60.still not right - UPDATE VIDS PAGE 5
Discussion in 'Engines' started by Riley, Sep 4, 2005.
  1. Riley
    Riley Forum Addict
    Burnley/Lancs
  2. Cabby Dave Forum Member
    Wirral
    managed to check site but too dark to play now. Thanks mate
  3. Riley
    Riley Forum Addict
    Burnley/Lancs
    More video's...hope they help [8(]
    Video 1:
    Showing fluctuating voltage at lambda on ecu plug...And then stable once i hold the WOT switch closed.
    And fluctuating once i let go again...Notice how it revs a lot slower/less responsively than video 2 below.
    http://uk.youtube.com/watch?v=JiUTY7F32vk
    Video 2:
    Connected to a cold BTS,see how it revs a lot more cleanly,and no popping.The BTS is maybe the fourth or fifth one ive tried,its a new v.a.g one.
    http://uk.youtube.com/watch?v=abpd39YRJOk
    Neil.
  4. moretorque Forum Member
    Reading
    how does it run at part throttle?
  5. Riley
    Riley Forum Addict
    Burnley/Lancs
    Its unresposive and slow to rev...Often when pulling away from traffic lights etc, ill hit the throttle to go and it will just pop/fluff/fart leaving me sat there...[8(]
    Neil.
  6. Cabby Dave Forum Member
    Wirral
    My fault, which is starting to sound like yours, is booked into renntech on tuesday with tim cooper to hopefully resolve. He helped build it so fingers crossed[8(] :lol: :)
  7. bens_cab Forum Junkie
    Ashford kent
    check the bottom pulley spoke to lee who does some work for g-werks he said the bottom pulley can move about on these casuing alot of advance retard on the ignition which would cause your symptons
  8. Riley
    Riley Forum Addict
    Burnley/Lancs
    The crank pully was removed ages ago to check it out...its mint as is the key way on the crank.I replaced the bolt with the bolt/washer from a mk1 dx engine at the same time too.
    Cheers,Neil.:)
  9. moretorque Forum Member
    Reading
    The car must be possessed then.[:^(]
    Get a priest in to perform an exorcism.
    [8(]
  10. Riley
    Riley Forum Addict
    Burnley/Lancs
    It really is mate[8(] Its got everyone! beaten...local mechanics, g60 people, mates.
    Don't know what else i can try or where i can go from here to be honest[8(]
    Neil.
  11. bens_cab Forum Junkie
    Ashford kent
    give g_werks a ring mate
  12. bens_cab Forum Junkie
    Ashford kent
    or take the ecu out pm toyotec get a new megasquirt and loom job done
    it so sounds like and ecu loom problem
  13. pigbladder Forum Addict
    cambridge , uk
    riley..have gwerks or pitstop had any ideas for you?
  14. Riley
    Riley Forum Addict
    Burnley/Lancs
    Nope...neither[8(]
    Well,they have had idea's but none have sorted the problem.[8(]
    The megasquirt has been suggested before, but id rather leave it all as it should be and find the cause...even though its an absolute mind bender.
    Its not getting to me as much with it currently being off the road.
    Neil.
  15. bens_cab Forum Junkie
    Ashford kent
    id start with a complete new loom and fusebox along with an ecu realy does sound ecu electrical
  16. Riley
    Riley Forum Addict
    Burnley/Lancs
    Would you believe i still have this problem? Well, its been 3 years!!! now, and yep its still there! :o [8(]
    Here's the latest info.
    The problem dissapears if i:
    Hold wot switch closed
    or
    Connect to a cold bts (with car upto temp)
    And some video's...
    Video 1:
    Video 2:
    Connected to a cold BTS on the slam panel (car upto temp) ,see how it revs a lot more cleanly,and no popping.The BTS is maybe the fourth or fifth one ive tried,its a new v.a.g one.
    And just to add, the problem is still there if i unplug the lambda.
    I have snipped the lambda signal wire up at the ecu, and the prob is still there.
    The lambda heater wiring checks out fine, voltage on one side, earth on the other.
    So although doing the things in the above post stops using lambda and stops the problem...The lambda checks out fine[:s]
    Today i tried a different ecu relay too, no difference...The absolute last thing i can think of is fuel pump relay but i reckon thats just clutching at straws big time.
    Neil.
  17. bens_cab Forum Junkie
    Ashford kent
    chnage the wot switch still sounds like a fueling prob can you get your ecu on a diag may show up some kind a fault
    also if you still cant find the fault maybe worth investing in standalone
  18. Riley
    Riley Forum Addict
    Burnley/Lancs
    Tried countless wot switches, ecu's etc etc.
    There is only one single part under the bonnet i haven't changed and thats the knock sensor.
    Just had the inlet manifold off to check it for cracks/damage and all is well [8(]
    Literally nothing else to try now...the end of a long and expensaive process of elimination.
    Neil.
  19. bens_cab Forum Junkie
    Ashford kent
    what was the inlet gasket like? could have been leaking?
    knock sensor would alter the timing if its pinking? try a new one then you have the full compliment of new parts
  20. Riley
    Riley Forum Addict
    Burnley/Lancs
    Why does nobody anywhere know whats wrong with it?![8(] [:x]
    Two mechanics, a lad i visited off rado forum, gwerks, c+r...40! yes 40!!! friggin pages on corrado forum...Nobody.
