Club GTI Weights & Measures
Discussion in 'Volkswagen Chat' started by A.N. Other, May 11, 2011.
    ** Contributions welcome **
    and other data
    8v engine outputs X
    16v engine outputs Link
    Small block 16v engine outputs Link
    FSI 16v engine outputs Link
    VR6 & V6 engine outputs Link
    4 cyl capacity combinations Link
    4 cyl block weights Link & Link
    Four cylinder head weights Link
    4 cyl block code locations Link & Link
    4 cyl block & head casting nos Link
    6 cyl block code location Link
    The 2 litre 16v head cutaway and maximum porting dimensions thread Link
    2Litre 16v Block Cutaway Pictures Link
    1.8T AUG Block Cutaway Pictures Link
    Car weights Link
    Stripped Mk2 Link
    Oily stuff
    Head weights Link & Link & Link
    Crank weights Link
    Block weights Link
    Sump weights Link
    16v combustion chamber in head Link & Link
    8v combustion chamber in head 30cc
    Bertils 8v combustion chamber in head 23.7cc
    Head gasket thicknesses Link
    16V Cam cover differences Link
    16v head differences thread - here
    ABF rods & pistons X
    4 cyl 47.8mm crank shells 32g
    2E rod 675g
    2E piston assy 455g
    Conrod, bearing & pin dimensions reference thread Link
    ABF hydraulic lifter weights Link
    KR cam profiles Link
    ABF cam profiles Link
    16v camshaft study Link
    KR vs ABF combustion chamber diffs Link
    9A-ABF block comparison Link
    Exhaust manifold sizes Link
    4cyl (EA827) oil pumps Link
    Dipstick lengths Link
    Fuel pump flow rates Link
    Injector flow rates Link
    VDO senders Link
    Clutch & flywheel weights Link & Link
    Gearbox weights Link & Link
    Gearbox ratios Link
    Gearbox ratios - using dyno data Link
    Driveshaft lengths Link
    Alternator/PAS brackets Link
    Electrics
    Temperature sender values range and colours, mix and match guide Link
    Suspension & brakes
    Mk1 Golf suspension geometry Link
    Mk2 suspension geometry Link
    Mk 1/2/3 axle widths Link
    Mk2/3/Corrado/Passat/Ibiza subframe widths Link
    Mk2/3/Corrado/Passat/Ibiza castor differences Link
    1.76 camber gauge Link
    Four wheel alignment gauge Link
    Anti roll bar diameters Link
    Wheel & tyre weight guide Link
    Brake discs Link
    Rear brake calipers Link
    Wheel & tyre weights Link
    Misc
    Mk2 wing diffs Link
    Mk2 Seats Link
    Mk1 polycarb windows 9.2kg
    Loctite info Link
    Thanks to various forum posters for the information linked, usual suspects and others.
    Post any links below and the info will be updated :thumbup:
  2. Admin Guest
    Thanks - added in.
  4. Admin Guest
    Good stuff. Mk1 & 2 suspension geometry added in also.
    Continuing to add to this.
    The intention is to have a banner around the forum hotlinked to it, to help folk passing by get to the key threads easily.
    Suggested threads welcome
  7. Tristan
    Anyone here ever weigh the underseal on a mk1?
    Cos I did.... Horrible boring dull painful mind-numbing job to take it off . But , basic tools and patience removes a surprising amount of weight! Car is a stock small block 2 dr RHD never crash repaired mk1 .
    the remainders... had to weigh it in 2 bags as couldn't fit it all in one.
    17.5 kgs is not to be sniffed at , and I prob failed to get another kg off .
    tshirt2k likes this.
